jQuery UI Widgets Forums Scheduler memory leak for jqxScheduler
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 5 years, 7 months ago.
  • memory leak for jqxScheduler #107345
    EvolveOne
    Hi Jqwidgets Team.
    I have a vue component which uses your Jwdiget scheduler component. To use it, in my .vue component, I got this line:
    import JqxScheduler from ‘jqwidgets-scripts/jqwidgets-vue/vue_jqxscheduler.vue’
    and somewhere I got this:
    this.mainDataAdapter = new jqx.dataAdapter(source2, { autoBind: true });
    When I move to thiscomponent, RAM increases. When I leave this component, RAM never decreases.
    Do I have to destroy something and how to avoid memory leak?
    memory leak for jqxScheduler #107365
    Hello EvolveOne,
    The jqxDataAdapter is a plug-in that is used to bind data for different widgets.
    Could you clarify it?
    It is an object that collects your data with dataAdapter.records option you could get these records.
    I tested this example and it seems the memory there is the same.
    Is it possible to provide us with an example that demonstrates this?
    https://www.jqwidgets.com
