jQuery UI Widgets Forums Editors NumberInput Max value for jqxNumberInput
This topic contains 6 replies, has 2 voices, and was last updated by  vdo 12 years, 4 months ago.
  • Max value for jqxNumberInput #12893
    vdo
    It seems that the max value for the jqxNumberInput is set at 99,999,999.99 by default? I have several cases that I want users to be able to enter a value larger than that. It just seems a bit silly to restrict it to that value. Let me know if i’m missing something or I should use the jqxInput instead and allow user to enter value in string and convert to decimal for storage?
    Max value for jqxNumberInput #12903
    Hi vdo,
    You can change it to a value which you want by setting the “max” property during the initialization.
    Max value for jqxNumberInput #13098
    vdo
    How can I input a value of say 1,000,000,000 into the jqxNumberInput as part of the grid cell it seems that the max value it allowed is 99,999,999.
    Setting the max value doesn’t work
    editor.jqxNumberInput({ max: 1000000000, spinButtons: false});
    Max value for jqxNumberInput #13099
    Hi vdo,
    The below code restricts the numberInput to 1000000000. Entered Values above the maximum value will be set to it i.e to 1000000000.
    $(“#numericInput”).jqxNumberInput({max: 1000000000, digits: 20, width: ‘250px’, height: ’25px’});
    Max value for jqxNumberInput #13103
    vdo
    Thanks for your help. Setting the digits property does the trick. The only minor issue I noticed is that when in edit mode it show only 8 digits.
    For example (I use the initeditor for the grid column):
    myGrid[1].initeditor = function(row, cellvalue, editor){
    editor.jqxNumberInput({digits: 20, decimalDigits: 0, spinButtons: false});
    I was able to input a value such as 235,000,000,000. When click on it again to go into edit mode, it shows only 8 digits => 23,500,000. I don’t think it should be chopping off current value like that. Is it a bug or am I missing something? Thanks.
    Max value for jqxNumberInput #13220
    Hi vdo,
    Setting the “digits” to 20 will enable you to enter 20 digits, but the “max” property is what restricts the input’s max value.
    Max value for jqxNumberInput #13241
    vdo
    I get it now. Thx. I have to set both digits and max property otherwise I’ll see the behavior in my previous post.
    editor.jqxNumberInput({digits: 15, max: 999999999999999);
