jQuery UI Widgets Forums Grid Max Height dropdown grid
This topic contains 2 replies, has 2 voices, and was last updated by  supun151515 10 years, 4 months ago.
  • Max Height dropdown grid #69674
    supun151515
    Hello, Good Day!,
    You can See my sample Fiddle and try to filter with some data. if no data to display or less than 8 rows, Then DropDown Grid still shows the same height with big empty area. I have tried to set autoheight=true, but it will mess the page with returning all data without scroll bars.
    Do you have any solution for removing empty area?
    Thank You,
    Supun
    Max Height dropdown grid #69688
    Hi Supun,
    I do not see any problem in this fiddle. The DropDown’s height is equal to the Grid’s height as it is expected. It’s auto-sizing the DropDown to be equal to the Grid’s height.
    Max Height dropdown grid #69698
    supun151515
    Hi Peter, As you mentioned, There is no error in this Fiddle. But please follow the steps as below;
    1. Search something in the filter box (Ex: type ‘000’ inside First Name filter box).
    2. You will see ‘Do Data to Display’.
    3. But still has the same grid height with big empty white box.
    I want to adjust grid height according to record count.
    Hope you will get my point.
    Thank You,
    Supun
