jQuery UI Widgets Forums Grid Master-Detail Grid – Filter not working.
This topic contains 2 replies, has 2 voices, and was last updated by  Keshavan 12 years ago.
  • Keshavan
    I have implemented a master-detail grid. While all is ok, there is one issue, when i select a row in master grid,
    the detail grid doesn\’t filter to show the corresponding detail grid records.
    jqWidget Version – 2.8
    Below is the explanation of my code,
    i have implemented a filter method (addfilter) in detail grid as part of it\’s data soure. This will filter based on 1
    column – \’GroupCompanyId\’ with an \’equal\’ condition.
      addfilter : function (gid)
    $(\"#companyGrid\").jqxGrid(\'clearfilters\');
    gidFilterGroup = new $.jqx.filter();
    filtervalue = gid;
    var filtercondition = \'equal\';
    gidFilter = gidFilterGroup.createfilter(\'numericfilter\', filtervalue, filtercondition);
    var filter_or_operator = 0;
    gidFilterGroup.addfilter(gidFilter);
    $(\"#companyGrid\").jqxGrid(\'addfilter\', \'GroupCompanyId\', gidFilterGroup);
    $(\"#companyGrid\").jqxGrid(\'applyfilters\');
    I call the \’addfilter\’ method from the master grid, when a row is selected in the master grid to show only the corresponding
    records in detail grid,
    $(\"#groupcompanyGrid\").on(\'rowselect\', function (event) {
    gid = event.args.row.GroupCompanyId;
    alert(\"Gid \" + gid);
    The filter is not working, Please let me know the issue.
    I have the full code below,
    <html lang=\"en\">
    <title id=\'Description\'>In order to enter in edit mode, click any of the \'Edit\' buttons. To save the changes, click the \'Save\' button in the popup dialog. To cancel the changes
    click the \'Cancel\' button in the popup dialog.</title>
    <link rel=\"stylesheet\" href=\"/Content/Site.css\" type=\"text/css\" />
    <link rel=\"stylesheet\" href=\"/jqWidgets/jqwidgets/styles/jqx.base.css\" type=\"text/css\" />
    <link rel=\"stylesheet\" href=\"/jqWidgets/jqwidgets/styles/jqx.ui-sunny.css\" type=\"text/css\" />
    <script type=\"text/javascript\" src=\"/JqWidgets/scripts/gettheme.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/scripts/jquery-1.8.3.min.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxcore.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxdata.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.edit.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.selection.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.pager.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.sort.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.filter.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.grouping.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.aggregates.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.columnsresize.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxgrid.columnsreorder.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxbuttons.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxscrollbar.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxmenu.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxwindow.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxlistbox.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxnumberinput.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxdropdownlist.js\"></script>
    <script type=\"text/javascript\" src=\"/JqWidgets/jqwidgets/jqxinput.js\"></script>
    <script type=\"text/javascript\" src=\"generatedata.js\"></script>
    <script type=\"text/javascript\">
    var theme = getDemoTheme();
    var gid = 1;
    var gidFilterGroup;
    var filtervalue;
    var filtercondition;
    var gidFilter;
    var data = {};
    var n1 = 0;
    var generaterow = function (id) {
    var row = {};
    row[\"GroupCompanyId\"] = id;
    row[\"GroupName\"] = \" \";
    row[\"Miscellaneous1\"] = \" \";
    row[\"Culture\"] = \" \";
    return row;
    datatype: \"json\",
    datafields:
    { name: \'GroupCompanyId\' },
    { name: \'GroupName\', type: \'string\' },
    { name: \'Miscellaneous1\', type: \'string\' },
    { name: \'Culture\', type: \'string\' }
    url: \'Company/GetGroupCompanies\'
    $(\"#groupcompanyGrid\").jqxGrid(
    width: 870,
    height: 105,
    theme: \'ui-sunny\',
    selectionmode: \'click\',
    keyboardnavigation: false,
    columns:
    { text: \'Name\', datafield: \'GroupName\', width: 400 },
    { text: \'Other Info\', datafield: \'Miscellaneous1\', width: 350 },
    { text: \'Culture\', datafield: \'Culture\', width: 120 }
    var generaterow1 = function (id) {
    var row = {};
    row[\"CompanyId\"] = id;
    row[\"GroupCompanyId\"] = gid;
    row[\"CompanyName\"] = \" \";
    row[\"AdminTel\"] = \" \";
    row[\"AdminEmail\"] = \" \";
    row[\"OtherInfo1\"] = \" \";
    row[\"OtherInfo2\"] = \" \";
    row[\"OtherInfo3\"] = \" \";
    return row;
    // Company Grid
    var source1 =
    datatype: \"json\",
    dataFields:
    { name: \'CompanyId\' },
    { name: \'CompanyName\' },
    { name: \'AdminTel\' },
    { name: \'AdminEmail\' },
    { name: \'OtherInfo1\' },
    { name: \'OtherInfo2\' },
    { name: \'OtherInfo3\' }
    url: \'Company/GetCompanies\',
    addrow: function (rowid, rowdata, position, commit)
    rowdata.GroupCompanyId = gid;
    $.ajax
    cache: false,
    dataType: \'json\',
    url:\'Company/Add\',
    data: rowdata,
    type: \"POST\",
    commit(true);
    alert(\"err\" + errorThrown);
    commit(false);
    updaterow: function (rowid, rowdata, commit)
    $.ajax(
    cache: false,
    dataType: \'json\',
    url: \'Company/Update\',
    data: rowdata,
    type: \"POST\",
    // alert(success);
    // alert(xhr.responseText);
    alert(\"entry saved!\");
    console.log(xhr.rowdata);
    commit(true);
    alert(\"Fails ... \");
    commit(false);
    filtervalue = gid;
    var dataAdapter1 = new $.jqx.dataAdapter(source1);
    // dataAdapter1.dataBind();
    var editrow = -1;
    // initialize the input fields.
    $(\"#companyid\").jqxInput({ theme: theme });
    $(\"#groupcompanyid\").jqxInput({ theme: theme });
    $(\"#companyname\").jqxInput({ theme: theme });
    $(\"#adminTel\").jqxInput({ theme: theme });
    $(\"#adminEmail\").jqxInput({ theme: theme });
    $(\"#otherInfo1\").jqxInput({ theme: theme });
    $(\"#otherInfo2\").jqxInput({ theme: theme });
    $(\"#otherInfo3\").jqxInput({ theme: theme });
    $(\"#companyid\").width(50);
    $(\"#companyid\").height(23);
    $(\"#groupcompanyid\").width(50);
    $(\"#groupcompanyid\").height(23);
    $(\"#companyname\").width(250);
    $(\"#companyname\").height(23);
    $(\"#adminTel\").width(250);
    $(\"#adminTel\").height(23);
    $(\"#adminEmail\").width(250);
    $(\"#adminEmail\").height(23);
    $(\"#otherInfo1\").width(250);
    $(\"#otherInfo1\").height(23);
    $(\"#otherInfo2\").width(250);
    $(\"#otherInfo2\").height(23);
    $(\"#otherInfo3\").width(250);
    $(\"#otherInfo3\").height(23);
    width: 1100,
    height: 250,
    source: dataAdapter1,
    selectionmode: \'multiplecellsextended\',
    // keyboardnavigation: false,
    sortable:true,
    ready: function () {
    addfilter(gid);
    autoshowfiltericon: true,
    columns:
    { text: \'Gid\', datafield: \'GroupCompanyId\', hidden: false, width: 200 } ,
    { text: \'Name\', datafield: \'CompanyName\', width: 200 },
    { text: \'Telephone\', datafield: \'AdminTel\', width: 110 },
    { text: \'Email\', datafield: \'AdminEmail\', width: 180 },
    { text: \'Other Info\', datafield: \'OtherInfo1\', width: 170 },
    { text: \'Other Info\', datafield: \'OtherInfo2\', width: 170 },
    { text: \'Other Info\', datafield: \'OtherInfo3\', width: 170 },
    text: \'Select/Update\', datafield: \'select\', columntype: \'button\', cellsrenderer: function () {
    return \"select\";
    editrow = row;
    var offset = $(\"#groupcompanyGrid\").offset();
    $(\"#popupWindow\").jqxWindow({ position: { x: parseInt(offset.left) + 80, y: parseInt(offset.top) + (-70) } });
    // get the clicked row\'s data and initialize the input fields.
    var dataRecord = $(\"#companyGrid\").jqxGrid(\'getrowdata\', editrow);
    $(\"#companyid\").val(dataRecord.CompanyId);
    $(\"#groupcompanyid\").val(gid);
    $(\"#companyname\").val(dataRecord.CompanyName);
    $(\"#adminTel\").val(dataRecord.AdminTel);
    $(\"#adminEmail\").val(dataRecord.AdminEmail);
    $(\"#otherInfo1\").val(dataRecord.OtherInfo1);
    $(\"#otherInfo2\").val(dataRecord.OtherInfo2);
    $(\"#otherInfo2\").val(dataRecord.OtherInfo3);
    // show the popup window.
    $(\"#popupWindow\").jqxWindow(\'open\');
    $(\"#GroupcompanyGrid\").jqxGrid(\'selectrow\', 0);
    width: 500, resizable: false, theme: \'ui-sunny\', isModal: true, autoOpen: false, cancelButton: $(\"#Cancel\"), modalOpacity: 0.01
    $(\"#popupWindow\").on(\'open\', function () {
    $(\"#companyid\").jqxInput(\'selectAll\');
    $(\"#Cancel\").jqxButton({ theme: \'ui-sunny\' });
    $(\"#Save\").jqxButton({ theme: \'ui-sunny\' });
    // update the edited row when the user clicks the \'Save\' button.
    $(\"#Save\").click(function () {
    if (editrow >= 0) {
    var row =
    { CompanyId: $(\"#companyid\").val(), GroupCompanyId: $(\"#gid\").val(), CompanyName: $(\"#companyname\").val(), AdminTel: $(\"#adminTel\").val(), AdminEmail: $(\"#adminEmail\").val(), OtherInfo1: $(\"#otherInfo1\").val(), OtherInfo2: $(\"#otherInfo2\").val(), OtherInfo3: $(\"#otherInfo3\").val() };
    var rowID = $(\'#companyGrid\').jqxGrid(\'getrowid\', editrow);
    $(\'#companyGrid\').jqxGrid(\'updaterow\', rowID, row);
    $(\"#popupWindow\").jqxWindow(\'hide\');
    // $(\"#companyGrid\").jqxGrid(\'selectrow\', 0);
    $(\"#addrowbutton\").jqxButton({ width: \'90\', height: \'30\', theme: \'ui-sunny\' });
    $(\"#updaterowbutton\").jqxButton({ width: \'90\', height: \'25\', theme: \'ui-sunny\' });
    $(\"#deleterowbutton\").jqxButton({ width: \'90\', height: \'30\', theme: \'ui-sunny\' });
    // update row.
    // create new row.
    $(\"#addrowbutton\").bind(\'click\', function () {
    var datainformation = $(\"#companyGrid\").jqxGrid(\'getdatainformation\');
    var rowscount = datainformation.rowscount;
    editrow = rowscount + 1;
    var datarow = generaterow1(rowscount + 1);
    alert(\"CompanyId \" + datarow.CompanyId);
    datarow.GroupCompanyId = gid;
    $(\"#companyGrid\").jqxGrid(\'addrow\', rowscount + 1, datarow, \'top\');
    // alert(\"rowcount \" + rowcount);
    $(\"#updaterowbutton\").bind(\'click\', function () {
    var selectedrowindex = $(\"#companyGrid\").jqxGrid(\'getselectedrowindex\');
    var rowscount = $(\"#companyGrid\").jqxGrid(\'getdatainformation\').rowscount;
    var id = $(\"#companyGrid\").jqxGrid(\'getrowid\', selectedrowindex);
    $(\"#companyGrid\").jqxGrid(\'updaterow\', id, datarow);
    <body class=\'default\'>
    <div id=\'jqxWidget\' style=\"font-size: 13px; font-family: Verdana; float: left;\">
    <h3>Group Company Info</h3>
    <br/>
    <div id=\"groupcompanyGrid\" >
    <h3>Company Info</h3>
    <br/>
    <div>
    <input id=\"addrowbutton\" type=\"button\" style=\"margin-top: 1px;\" value=\" (+) record\" />
    <input id=\"deleterowbutton\" type=\"button\" style=\"margin-top: 1px;\" value=\" (-) record\" />
    <br/>
    <div id=\"companyGrid\">
    <div style=\"margin-top: 30px;\">
    <div id=\"cellbegineditevent\"></div>
    <div style=\"margin-top: 10px;\" id=\"cellendeditevent\"></div>
    <div id=\"popupWindow\">
    <div>Update Company Information</div>
    <div style=\"overflow: hidden;\">
    <table>
    <tr>
    <td align=\"right\">CompanyId:</td>
    <td align=\"left\">
    <input id=\"companyid\" /></td>
    </tr>
    <tr>
    <td align=\"right\">GroupCompanyId:</td>
    <td align=\"left\">
    <input id=\"groupcompanyid\" /></td>
    </tr>
    <tr>
    <td align=\"right\">Company Name:</td>
    <td align=\"left\">
    <input id=\"companyname\" /></td>
    </tr>
    <tr>
    <td align=\"right\">Telephone:</td>
    <td align=\"left\">
    <input id=\"adminTel\" /></td>
    </tr>
    <tr>
    <td align=\"right\">Email:</td>
    <td align=\"left\">
    <input id=\"adminEmail\" /></td>
    </tr>
    <tr>
    <td align=\"right\">Other Info:</td>
    <td align=\"left\">
    <input id=\"otherInfo1\" /></td>
    </tr>
    <tr>
    <td align=\"left\">
    <input id=\"otherInfo2\" /></td>
    </tr>
    <tr>
    <td align=\"left\">
    <input id=\"otherInfo3\" /></td>
    </tr>
    <tr>
    <td align=\"right\"></td>
    <td style=\"padding-top: 1px;\" align=\"right\">
    <input style=\"margin-right: 5px;\" type=\"button\" id=\"Save\" value=\"Save\" /><input id=\"Cancel\" type=\"button\" value=\"Cancel\" /></td>
    </tr>
    </table>
    Keshavan
    The code will not work because the custom function – addfilter should not be part of the source object and also the code that tries to call that function actually does not call it. Please, look at this sample: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/masterdetails.htm?web. It shows how Master-Details is expected to be implemented with jqxGrid.
    Keshavan
    Thanks for the quick response, will go through the sample code you have sent and complete it.
    Keshavan
