jQuery UI Widgets › Forums › Grid › Mapping issue with bool JSON data
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 10 years, 5 months ago.
I am using jqxgrid and have joined two JSON requests. All information except the ‘bool’ data is displaying in the grid. The missing values are ‘relinquishable’, ‘enabled’, and ‘settable’. I am new to this and I am not sure if the issue is in my mapping or if it is related to displaying boolean data in the grid. Any help would be greatly appreciated.
Here is the JSON response:
[{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Dashboard Demo”,”pointLocator”:{“dataTypeId”:1,”changeTypeId”:1,”settable”:true,”alternateBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:””,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:””,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:””,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:””,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:””,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:””,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:””,”maxChange”:0,”volatility”:0,”attractionPointId”:1,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.binary”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”BINARY”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Binary”,”xid”:”binary”},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase A (A)”,”xid”:”DP_119588″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase A (A)”,”xid”:”DP_370045″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase A (A)”,”xid”:”DP_992791″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase B (A)”,”xid”:”DP_278103″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase B (A)”,”xid”:”DP_394777″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase B (A)”,”xid”:”DP_840606″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase C (A)”,”xid”:”DP_331467″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase C (A)”,”xid”:”DP_222324″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”50″,”min”:50,”max”:300,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Current Phase C (A)”,”xid”:”DP_100375″},{“enabled”:true,”validationMessages”:{},”unit”:”°F”,”deviceName”:”Virtual Data Source”,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:””,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:””,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:””,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:””,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”1″,”min”:0,”max”:100,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:””,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:””,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”INTERVAL”,”intervalType”:”AVERAGE”},”name”:”Demo Analog Point”,”xid”:”DP_028092″},{“enabled”:true,”validationMessages”:{},”unit”:”°F”,”deviceName”:”Virtual Data Source”,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:””,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:””,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:””,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:””,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”1″,”min”:0,”max”:100,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:””,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:””,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”INTERVAL”,”intervalType”:”AVERAGE”},”name”:”Demo Analog Point 2″,”xid”:”DP_596621″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Dummy”,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:3,”settable”:true,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:”1″,”min”:0,”max”:100,”change”:1,”roll”:true,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Dummy”,”xid”:”DP_993944″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:3,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:”100″,”min”:100,”max”:999999999,”change”:5,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Energy Accumulator (kWh)”,”xid”:”DP_614346″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:3,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:”100″,”min”:100,”max”:999999999,”change”:5,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Energy Accumulator (kWh)”,”xid”:”DP_622129″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:3,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:”100″,”min”:100,”max”:999999999,”change”:5,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Energy Accumulator (kWh)”,”xid”:”DP_399285″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Dashboard Demo”,”pointLocator”:{“dataTypeId”:2,”changeTypeId”:4,”settable”:true,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:”1″,”values”:[1,2,3,4,5,6,7,8,9],”roll”:true,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.multistate”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”MULTISTATE”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Multistate”,”xid”:”multistate”},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor A”,”xid”:”DP_984239″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor A”,”xid”:”DP_348223″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor A”,”xid”:”DP_268535″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor B”,”xid”:”DP_686983″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor B”,”xid”:”DP_347418″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor B”,”xid”:”DP_916776″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor C”,”xid”:”DP_806477″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor C”,”xid”:”DP_077116″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”.85″,”min”:0.8,”max”:1,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Power Factor C”,”xid”:”DP_279767″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power A (kW)”,”xid”:”DP_355369″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power A (kW)”,”xid”:”DP_556556″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power A (kW)”,”xid”:”DP_805604″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power B (kW)”,”xid”:”DP_368591″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power B (kW)”,”xid”:”DP_364171″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power B (kW)”,”xid”:”DP_029774″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power C (kW)”,”xid”:”DP_241169″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power C (kW)”,”xid”:”DP_422050″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”25″,”min”:20,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Real Power C (kW)”,”xid”:”DP_202333″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Dashboard Demo”,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:2,”settable”:true,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:”1″,”min”:0,”max”:100,”maxChange”:0.01,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Temperature”,”xid”:”temperature”},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Dashboard Demo”,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:2,”settable”:true,”alternateBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:”1″,”min”:0,”max”:100,”maxChange”:0.01,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:””,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:””,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:””,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”1″,”min”:0,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:””,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:””,”maxChange”:0,”volatility”:0,”attractionPointId”:1,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage”,”xid”:”voltage”},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage A-N (V)”,”xid”:”DP_698831″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage A-N (V)”,”xid”:”DP_287036″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage A-N (V)”,”xid”:”DP_033512″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage B-N (V)”,”xid”:”DP_549856″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage B-N (V)”,”xid”:”DP_924123″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage B-N (V)”,”xid”:”DP_440955″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 1″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage C-N (V)”,”xid”:”DP_596850″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 2″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage C-N (V)”,”xid”:”DP_390622″},{“enabled”:true,”validationMessages”:{},”unit”:””,”deviceName”:”Meter 3″,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:null,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:null,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:null,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”270″,”min”:269,”max”:287,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:null,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:null,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:null,”maxChange”:0,”volatility”:0,”attractionPointId”:0,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”ON_CHANGE”},”name”:”Voltage C-N (V)”,”xid”:”DP_077192″},{“enabled”:true,”validationMessages”:{},”unit”:”°F”,”deviceName”:”Virtual Data Source”,”pointLocator”:{“dataTypeId”:3,”changeTypeId”:6,”settable”:false,”alternateBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.alternate”,”args”:[]}},”brownianChange”:{“startValue”:””,”min”:0,”max”:0,”maxChange”:0,”description”:{“key”:”dsEdit.virtual.changeType.brownian”,”args”:[]}},”incrementAnalogChange”:{“startValue”:””,”min”:0,”max”:0,”change”:0,”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”incrementMultistateChange”:{“startValue”:””,”values”:[],”roll”:false,”description”:{“key”:”dsEdit.virtual.changeType.increment”,”args”:[]}},”noChange”:{“startValue”:””,”description”:{“key”:”dsEdit.virtual.changeType.noChange”,”args”:[]}},”randomAnalogChange”:{“startValue”:”1″,”min”:0,”max”:200,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomBooleanChange”:{“startValue”:”true”,”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”randomMultistateChange”:{“startValue”:””,”values”:[],”description”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]}},”analogAttractorChange”:{“startValue”:””,”maxChange”:0,”volatility”:0,”attractionPointId”:1,”description”:{“key”:”dsEdit.virtual.changeType.attractor”,”args”:[]}},”sinusoidalChange”:{“startValue”:null,”amplitude”:0,”offset”:0,”period”:0,”phaseShift”:0,”description”:{“key”:”dsEdit.virtual.changeType.sinusoidal”,”args”:[]}},”configurationDescription”:{“key”:”dsEdit.virtual.changeType.random”,”args”:[]},”className”:”VirtualPointLocatorVO”,”dataTypeMessage”:{“key”:”common.dataTypes.numeric”,”args”:[]},”relinquishable”:false,”dataPointSaveHandler”:null},”dataType”:”NUMERIC”,”loggingProperties”:{“type”:”INTERVAL”,”intervalType”:”AVERAGE”},”name”:”random”,”xid”:”DP_275295″}]
And here is the code:
<script type="text/javascript"> $(document).ready(function () { // prepare the data var dataPointsource = { datatype: "json", datafields: [ { name: 'relinquishable', map: 'pointLocator>relinquishable', type: 'bool'}, { name: 'enabled', map: 'pointLocator>enable', type: 'bool' }, { name: 'settable', map: 'pointLocator>settable', type: 'bool'}, { name: 'deviceName', type: 'string' }, { name: 'name', type: 'string' }, { name: 'xid', type: 'string' } ], url: "http://localhost:8080/rest/v1/dataPoints", data: { featureClass: "P", style: "full", maxRows: 100, } }; var dataPointAdapter = new $.jqx.dataAdapter(dataPointsource, { //loadComplete: function () { autoBind: true, beforeLoadComplete: function(records) { var data = new Array(); for (var i = 0; i < records.length; i++) { var datapoint = records[i]; data.push(datapoint); } return data; } }); var dataValuesource = { datatype: "json", datafields: [ { name: 'relinquishable', type: 'bool', map: 'relinquishable', values:{source: dataPointAdapter.records, name: 'relinquishable', type: 'bool' }}, { name: 'enabled', type: 'bool', map: 'enabled', values:{source: dataPointAdapter.records, name: 'enabled', type: 'bool' }}, { name: 'settable', type: 'bool', map: 'settable', values:{source: dataPointAdapter.records, name: 'settable', type: 'bool' }}, { name: 'deviceName', type: 'string', map: 'deviceName', values:{source: dataPointAdapter.records, name: 'deviceName' }}, { name: 'name', type: 'string', map: 'name', values:{source: dataPointAdapter.records, name: 'name' }}, { name: 'xid', type: 'string' }, { name: 'value', type: 'string' }, { name: 'renderedValue', type: 'string' }, { name: 'xid', type: 'string', map: 'xid', values:{source: dataPointAdapter.records, name: 'xid' }} ], url: "http://localhost:8080/rest/v1/realtime", data: { featureClass: "P", style: "full", maxRows: 100, } }; var dataValueadapter = new $.jqx.dataAdapter(dataValuesource, { autobind: true, }); $("#jqxgrid").jqxGrid( { width: 1000, source: dataValueadapter, selectionmode: 'multiplecellsextended', pageable: true, autoheight: true, columns: [ { text: 'Relinquishable', datafield: 'relinquishable', width: 150 }, { text: 'Enabled', datafield: 'enabled', width: 150 }, { text: 'Settable', datafield: 'settable', width: 150 }, { text: 'Device Name', datafield: 'deviceName', width: 150 }, { text: 'Name', datafield: 'name', width: 150 }, { text: 'xID', datafield: 'xid', width: 150 }, { text: 'Value', datafield: 'value', width: 200 }, { text: 'Rendered Value', datafield: 'renderedValue', width: 200 } ] }); }); </script>
Thank you.
Hello wingnut,
Could you, please, recreate the example in JSFiddle with only several records for easier testing?
