jQuery UI Widgets Forums Grid long Filter data issue
This topic contains 4 replies, has 2 voices, and was last updated by  pcasals 6 years ago.
  • long Filter data issue #105167
    pcasals
    I am testing jqxGrid and I have an issue I have to solve before purchasing. I am developing with VS2017/C#/jQuery & boostrap. I have a grid with many columns, and users must be able to search for more than one column. Everything works ok if I filter for 1 or 2 columns. If I add a 3rd filter, ULR grows over 3000 characters, so the browser is rejecting the request. Is it possible to post filter data, instead of sending them by GET?
    Thanks in advance,
    Pedro
    long Filter data issue #105169
    In this case you should use Post request. Get works until 2500 chars
    long Filter data issue #105170
    pcasals
    I Know that I should post it. But in what event do I have to implement the ajax call? Do you have an example?
    Pedro
    long Filter data issue #105280
    pcasals
    Hi!
    I do not know how to do it. Any clue, or example?
    Pedro
    long Filter data issue #105315
    pcasals
    I have found the solution. I have overwritten the loadServerData function of the dataadapter, using ajax post. This is my method, if it helps someone:
    loadServerData: function (serverdata, source, callback) {
    type: “POST”,
    dataType: source.datatype,
    url: source.url,
    data: serverdata,
    callback({ records: data.records, totalrecords: data.totalrecords });
    error: function (XMLHttpRequest, textStatus, errorThrown) {
    alert(“some error”);
