jQuery UI Widgets Forums Grid [localizestrings] filtershowrowdatestring not working for me
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 11 months ago.
  • al3dv
    Hi All, I have a problem about the localizestrings.
    I’m not able to translate the filtershowrowdatestring.
    I’m able to translate the other item correctly, but this item is always in english:
    `$(“#jqxgrid”).bind(‘bindingcomplete’, function () {
    var localizationobj = {};
    var patterns = {
    d: “dd/MM/yyyy”,
    D: “dddd, d. MMMM yyyy”,
    t: “HH:mm”,
    T: “HH:mm:ss”,
    f: “dddd, d. MMMM yyyy HH:mm”,
    F: “dddd, d. MMMM yyyy HH:mm:ss”,
    M: “dd MMMM”,
    Y: “MMMM yyyy”
    localizationobj.patterns = patterns;
    localizationobj.currencysymbol = ” “;
    localizationobj.decimalseparator = “,”;
    localizationobj.thousandsseparator = “.”;
    localizationobj.filterstringcomparisonoperators = [‘vuoto’, ‘non vuoto’, ‘contiene’, ‘contiene(Maiuscole/Minuscole)’,
    ‘non contiene’, ‘non contiene(Maiuscole/Minuscole)’, ‘inizia con’, ‘inizia con(Maiuscole/Minuscole)’,
    ‘finisce con’, ‘finisce con(Maiuscole/Minuscole)’, ‘uguale’, ‘uguale(Maiuscole/Minuscole)’, ‘null’, ‘non null’];
    localizationobj.filternumericcomparisonoperators = [‘uguale’, ‘non uguale’, ‘minore di’, ‘minore di o uguale’, ‘maggiore di’, ‘maggiore di o uguale’, ‘null’, ‘non null’];
    localizationobj.filterdatecomparisonoperators = [‘uguale’, ‘non uguale’, ‘minore di’, ‘minore di o uguale’, ‘maggiore di’, ‘maggiore di o uguale’, ‘null’, ‘non null’];
    localizationobj.filterbooleancomparisonoperators = [‘uguale’, ‘non uguale’];
    localizationobj.filterclearstring = “Rimuovi”;
    localizationobj.filterstring = “Filtra”;
    localizationobj.sortascendingstring = “Ordine Ascendente”;
    localizationobj.sortdescendingstring = “Ordine Discendente”;
    localizationobj.sortremovestring = “Rimuovere Ordinamento”;
    localizationobj.filtershowrowstring = “Mostra righe con:”;
    localizationobj.filterorconditionstring = “o”;
    localizationobj.filterandconditionstring = “e”;
    localizationobj.filterchoosestring = “Prego scegliere:”;
    localizationobj.emptydatastring = “Nessun dato da mostrare”;
    localizationobj.pagergotopagestring = “Vai a pagina:”;
    localizationobj.pagershowrowsstring = “Mostra righe:”;
    localizationobj.pagerrangestring = ” di “;
    localizationobj.pagerpreviousbuttonstring = “prec.”;
    localizationobj.pagernextbuttonstring = “succ.”;
    localizationobj.groupsheaderstring = “Trascina una colonna qui per raggruppare”;
    localizationobj.groupbystring = “Raggruppa per questa colonna”;
    localizationobj.groupremovestring = “Rimuovi dal raggruppamento”;
    localizationobj.filtershowrowdatestring = “Mostra righe con data:”;
    localizationobj.filterselectallstring = “(Seleziona tutto)”;
    localizationobj.validationstring = “Entered value is not valid”;
    localizationobj.filterselectstring = “Select Filter”;
    localizationobj.loadtext = “Caricamento…”;
    localizationobj.clearstring = “Rimuovi”;
    localizationobj.todaystring = “Oggi”;
    $(“#jqxgrid”).jqxGrid(‘localizestrings’, localizationobj);
    Someone have a similar problem?
    thanks and have a nice day
    Hi al3dv,
    Thank you for the feedback. The missing localization string is confirmed.
