jQuery UI Widgets Forums Grid localization of two grids on same page
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 11 years, 3 months ago.
  • localization of two grids on same page #49551
    mallepaddi
    Hi
    had two grids on same page and following is our localization …
    Somehow right hand side grid (XYZ grid), still showing default “Loading” rather than showing “XYZ progress …”
    $(‘#abcgrid’).jqxGrid({
    localization: getABCLocalization(),
    $(‘#xyzgrid’).jqxGrid({
    localization: getXYZLocalization(),
    var getABCLocalization = function () {
    var localizationobj = {};
    localizationobj.loadtext = “<font color=’#AB1034′>ABC progress …</font>”;
    localizationobj.emptydatastring = “ABC ABC”;
    return localizationobj;
    var getXYZLocalization = function () {
    localizationobj.loadtext = “<font color=’#AB1034′>XYZ progress …</font>”;
    localizationobj.emptydatastring = “XYZ XYZ”;
    localization of two grids on same page #49604
    Hello mallepaddi,
    We tested your sample and it works fine. The issue may originate elsewhere in your code.
    localization of two grids on same page #49609
    mallepaddi
    HI
    Do you have a sample to look at it ?
    localization of two grids on same page #49654
    Hi mallepaddi,
    Here is the example (based on the demo Default Functionality). Note that getXYZLocalization should be defined before initializing the grid.
                var url = "../sampledata/products.xml";
                var productNameUpdate = false;
                    datatype: "xml",
                        { name: 'ProductName', type: 'string' },
                        { name: 'QuantityPerUnit', type: 'int' },
                        { name: 'UnitPrice', type: 'float' },
                        { name: 'UnitsInStock', type: 'float' },
                        { name: 'Discontinued', type: 'bool' }
                    root: "Products",
                    record: "Product",
                    url: url,
                        if (productNameUpdate == true) {
                            commit(true);
                    if (value < 20) {
                        return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>';
                    else {
                    localizationobj.loadtext = "<font color='#AB1034'>XYZ progress …</font>";
                    localizationobj.emptydatastring = "XYZ XYZ";
                // initialize jqxGrid
                $("#jqxgrid").jqxGrid(
                    width: 670,
                    altrows: true,
                    enabletooltips: true,
                      { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250 },
                      { text: 'Quantity per Unit', columngroup: 'ProductDetails', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 120 },
                      { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 100 },
                      { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
                      { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' }
                    columngroups: [
                        { text: 'Product Details', align: 'center', name: 'ProductDetails' }
                    ready: function () {
                        $("#jqxgrid").jqxGrid("showloadelement");
                    var column = args.datafield;
                    if (column == "ProductName") {
                        productNameUpdate = true;
                    } else {
            <div id="jqxgrid">
