jQuery UI Widgets › Forums › Grid › Localdata, addrow & cellsformat problem
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 5 years, 6 months ago.
I have problem with Add/Edit localdata type: ‘JSON’ and cellsformat.
when I successfuly add or edit new data, the cellsformat doesn’t apply the current cell.Then I try to apply this Case to the Code from Sample, but this problem still happen.
I need your help, thank you
<!DOCTYPE html> <html lang="en"> <head> <title id='Description'>This example shows how to create a Grid from JSON data.</title> <link rel="stylesheet" href="../../../jqwidgets/styles/jqx.base.css" type="text/css" /> <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" /> <meta name="viewport" content="width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1" /> <script type="text/javascript" src="../../../scripts/jquery-1.12.4.min.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../../scripts/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { var url = "../../sampledata/beverages.txt"; // prepare the data var source = { datatype: "json", datafields: [ { name: 'name', type: 'string' }, { name: 'type', type: 'string' }, { name: 'calories', type: 'int' }, { name: 'totalfat', type: 'string' }, { name: 'protein', type: 'string' } ], id: 'id', url: url, addrow: function (rowid, rowdata, position, commit) { // synchronize with the server - send insert command // call commit with parameter true if the synchronization with the server is successful //and with parameter false if the synchronization failed. // you can pass additional argument to the commit callback which represents the new ID if it is generated from a DB. commit(true); }, }; var dataAdapter = new $.jqx.dataAdapter(source); $("#grid").jqxGrid( { width: getWidth('Grid'), source: dataAdapter, columnsresize: true, columns: [ { text: 'Name', datafield: 'name', width: 250 }, { text: 'Beverage Type', datafield: 'type', width: 250 }, { text: 'Calories', datafield: 'calories', cellsformat: 'd2', width: 180 }, { text: 'Total Fat', datafield: 'totalfat', width: 120 }, { text: 'Protein', datafield: 'protein', minwidth: 120 } ] }); }); function add() { var datarow = [ { name : 'abc', type : 'def', calories : '10', totalfat : 'ghi', protein : 'jkl', } ]; $("#grid").jqxGrid('addrow', null, datarow); } </script> </head> <body class='default'> <div id="grid"></div> <div style="position: absolute; bottom: 5px; right: 5px;"> <a href="https://www.jqwidgets.com/" alt="https://www.jqwidgets.com/"><img alt="https://www.jqwidgets.com/" title="https://www.jqwidgets.com/" src="https://www.jqwidgets.com/wp-content/design/i/logo-jqwidgets.png"/></a> </div> <button onclick=add()>Add</button> </body> </html>
Please, refer to http://jsfiddle.net/jqwidgets/fZhEc/
It should help you.
PeterjQWidgets Team
https://www.jqwidgets.com/ -
