jQuery UI Widgets Forums Grid Loader does not show when using virtual paging
This topic contains 2 replies, has 2 voices, and was last updated by  Hristo 6 years, 8 months ago.
  • sherlyn
    I am using virtual mode with paging. Source from ajax.
    However, the loader is not show while waiting data return from ajax. How can we do this?
    { name: ‘RowNum’, type: ‘int’ }
    localdata: ‘[{}]’,
    totalrecords: 0
    return AjaxApp.getDataFromServer(params.startindex, params.endindex);
    $(“#searchResultGrid”).jqxGrid(
    width: “100%”,
    pagermode: ‘default’,
    virtualmode: true,
    altrows: true, autoshowloadelement: true,
    { text: ‘No’, datafield: ‘RowNum’, width: “5%” }
    sherlyn
    continues code above…
    var AjaxApp = (function () {
    var first = true;
    var getFormData = function (start_rec, end_rec) {
    var params = {};
    if (start_rec != null) {
    params.sta_rec_num = start_rec;
    if (end_rec != null) {
    params.end_rec_num = end_rec;
    return (params);
    var getDataFromServer = function (startindex, endindex) {
    var svr_data = [];
    url: ‘@Request.ApplicationPath/…./doSearch’,
    data: getFormData(startindex, endindex),
    type: “GET”,
    async: false,
    dataType: ‘json’,
    cache: false,
    success: function (result) {
    svr_data = result;
    error: function (xhr, status, error) {
    return svr_data;
    var getTotRec = (function () {
    var tot_rec = ‘0’;
    url: ‘@Request.ApplicationPath/…./doGetTotalRec’,
    data: getFormData(),
    type: “GET”,
    async: false,
    dataType: ‘json’,
    cache: false,
    tot_rec = result;
    return (tot_rec);
    return {
    getTotRec:getTotRec,
    getDataFromServer: getDataFromServer
    function refresh()
    source.totalrecords = AjaxApp.getTotRec();
    $(‘#searchResultGrid’).jqxGrid(‘gotopage’, 0);
    $(“#searchResultGrid”).jqxGrid(‘updatebounddata’);
    Hello sherlyn,
    You could use the showloadelement method of the jqxGrid.
    Also, bind to the bindingcomplete event and when it is fired use the hideloadelement method.
