jQuery UI Widgets Forums Grid Load jqxgrid on button click
This topic contains 4 replies, has 3 voices, and was last updated by  harsh 9 years, 9 months ago.
  • Load jqxgrid on button click #72357
    vls
    I need to load jqxGrid based on the values selected in a jqxListBox. The scenario is I am selecting the values from jqxListBox and then Click on a button. When the button click event is fired I need to load the jqxGrid. The jqxgrid should be blank with column names on the initial page load.
    Please help me on this.
    Thanks.
    Load jqxgrid on button click #72374
    ivailo
    Hi vls,
    Here is the example.
    This article also can be helpful.
    Ivailo Ivanov
    Load jqxgrid on button click #72424
    vls
    Perfect, This is what exactly I am looking for. Thank you very much.
    Load jqxgrid on button click #76869
    harsh
    Hi ,
    I tried the above example and it is not working for me. Here is my code.
    $(“#addselected”).click(function(){
    debugger
    var offtypeid = $(“#offTypeid”).val();
    var rows = $(“#grid1”).jqxGrid(‘getrows’);
    var str = JSON.stringify(rows);
    url: “/OfficeTerritory/AddSelected”,
    type: “POST”,
    data: {
    delchkboxloglist: str,
    officeid: officeid,
    offtypeid: offtypeid
    dataType: “json”,
    success: function(data){
    source.localdata = data;
    $(‘#grid’).jqxGrid(‘updatebounddata’);
    public JsonResult AddSelected(string officeid, string offtypeid, string delchkboxloglist)
    List<Location> model = new JavaScriptSerializer().Deserialize<List<Location>>(delchkboxloglist);
    OfficeTypeLocation otl = new OfficeTypeLocation();
    otl.AddOfficeTypeLocation(officeid, offtypeid, model);
    List<OfficeTypeLocation> list = otl.GetOfficeTypeLocation(Convert.ToInt16(offtypeid), Convert.ToInt16(officeid));
    return Json(list, JsonRequestBehavior.AllowGet);
    Load jqxgrid on button click #76870
    harsh
    I got it working if i remove this line source.localdata = data;
    thanks,
    harsh
