jQuery UI Widgets Forums Grid Load indicator
This topic contains 7 replies, has 2 voices, and was last updated by  Yogesh Singh 11 years, 5 months ago.
  • Load indicator #47736
    Yogesh Singh
    Hi
    I have a grid in which data gets populated from the Ajax call to the web method which runs database sql and return rows
    Though grid displays data but it doesn’t display the load indicator as sometimes data takes a min to display
    Could you please point me to the right direction here’s my code
    type: ‘POST’,
    dataType: ‘json’,
    cache: false,
    url: ‘AddEditView.aspx/LoadLookUpSearchGrid’,
    data: JSON.stringify({ FilterType: $(‘select#ddlFilterType’).val() , Id: $(“#txtId”).val() , Name: $(“#txtName”).val(), SearchText: ”, FilterRows: filterGridRows}),
    success: function (data) {
    var source = data.d;
    SetSearchFields($(‘select#ddlFilterType option:selected’).text(), source);
    error: function (err) {
    alert(err.text + ” : ” + err.status);
    if (fieldName == “Contract Manager”) {
    source =
    datatype: “xml”,
    { name: ‘MANAGERID’, type: ‘string’ },
    { name: ‘NAME’, type: ‘string’ }
    async: false,
    root: “Manager”,
    localdata: source
    $(“#divLookupSearch”).jqxGrid(
    width: ‘100%’,
    source: searchViewGridDataAdapter,
    selectionmode: ‘checkbox’,
    columns: columns
    Load indicator #47738
    Hi Yogesh Singh,
    It will not display load indicator if you bind the Grid to local data, because it that code that is what happens. You bind the Grid to your Ajax result so the Ajax call is not handled by jqxDataAdapter as shown in our demos. If you do it in the way shown in the live demos and help topics, the load indicator would be displayed, but it will not be displayed when you load the widget from Local Data/Array, because that happens simultaneously and nothing should be displayed.
    Load indicator #47741
    Yogesh Singh
    Thanks for the reply peter
    But i dont follow where do i have to make changes in the following code
    $(“#btnSearch”).jqxButton({ width: ’80’, height: ’25’ });
    $(“#btnSearch”).bind(‘click’, function () {
    if ($(‘#popupWindow’).jqxValidator(‘validate’))
    LoadLookUpSearchGrid();
    function LoadLookUpSearchGrid() {
    var filterRows = getGridRows();
    type: ‘POST’,
    dataType: ‘json’,
    async: false,
    cache: false,
    function SetSearchFields(fieldName, source) {
    var columns;
    if (fieldName == “Customer”) {
    source =
    datatype: “xml”,
    { name: ‘CUST_ID’, type: ‘string’ },
    { name: ‘CUST_NAME’, type: ‘string’ }
    root: “Customer”,
    localdata: source
    columns = [
    { text: ‘Customer ID’, dataField: ‘CUST_ID’, width: ‘30%’ },
    { text: ‘Customer Name’, dataField: ‘CUST_NAME’, width: ‘65%’ }
    lookupSearchResultGrid(source, columns,fieldName);
    function lookupSearchResultGrid(source, columns,fieldName) {
    var searchViewGridDataAdapter = new $.jqx.dataAdapter(source);
    // Create jqxGrid.
    width: ‘100%’,
    columns: columns
    // columnsArray = $(“#divLookupSearch”).jqxGrid(‘columns’);
    // var colCount = columnsArray.records.length
    var value = columns[0].dataField;
    if(searchViewGridDataAdapter.records.length!=1)
    $(“#popupWindow”).jqxWindow(‘show’);
    ShowSearchFieldsLabel(fieldName);
    if($(‘#divLookupSearch’).jqxGrid(‘getselectedrowindexes’).length > 0)
    $(“#divLookupSearch”).jqxGrid(‘clearselection’);
    $(“#txtId”).val(“”);
    $(“#txtName”).val(“”);
    else
    AddNewFilter(searchViewGridDataAdapter.records[0],value);
    $(“#txtValue”).val(“”);
    Load indicator #47742
    Hi Yogesh Singh,
    I suggest you to look at the Grid’s Live demos and also the help documentation topics about jqxGrid. There you will find how to bind the widget through jqxDataAdapter.
    Load indicator #47750
    Yogesh Singh
    I did refer the demos such as binding to xml and
    in order to parse xml data comin in from my webmethod i need to have a source which binds the data to its localdata property i dont know if there is any other way and adaptor to load data and grid to display the data from loaded adaptor
    the examples basically refer either text files or array
    Load indicator #47760
    Yogesh Singh
    In addition to that i have also tried to show load image explicitly using
    $(‘#divLookupSearch’).jqxGrid(‘showloadelement’);
    setTimeout(function() {
    }, 500);
    but still it doesnt show any suggestions following is the code snippet of ajax call and grid definition
    type: ‘POST’,
    dataType: ‘json’,
    async: false,
    cache: false,
    $(‘#divLookupSearch’).jqxGrid(‘hideloadelement’);
    width: ‘100%’,
    columns: columns
    Load indicator #47761
    Hi Yogesh Singh,
    There are samples with XML Binding so may be you will want to look at them, too. You cannot display a load indicator in the way you try to use jqxGrid, because in general you bind the Grid after your data is downloaded so the only solution if the load indicator is important for you is to use jqxDataAdapter to load your data and set its “url” and other required settings.
    Load indicator #47851
    Yogesh Singh
    Thanks for your reply could you please provide an example to implement my scenario i tried few setting but it didnt work
    what all settings would be required should i have my grid to any particular event of the adaptor to make sure data is loaded
