jQuery UI Widgets Forums Grid Load grid state
This topic contains 5 replies, has 5 voices, and was last updated by  maryam_banoo 9 years, 6 months ago.
  • Load grid state #18350
    naatha
    When i save and load a grid state, which has pinned columns, it shows all the pinned columns.
    But, when i move the horizontal scroll bar, the pinned columns also move. Does not act like a pin column.
    I add render method after load, but did not work.
    Need some help.
    Load grid state #18395
    Hi naatha,
    Please, provide a sample which demonstrates your scenario and which version of jQWidgets do you use?
    Load grid state #18413
    naatha
    I use v 2.7
    scenario:
    In my project, i have the following options:
    can pin/unpin column
    can hide/show column
    can save/load the grid state
    I can save the state with some of the columns are pinned and some of the column are hidden.
    But when i load the saved state, it displays all the pinned columns (can see the background color changed).
    but when i move the horizontal scroll bar, the pinned columns also move.
    I had the same problem when i pinned the column using
    $(‘#jqxgrid’).jqxGrid(‘pincolumn’, columndatafield);
    Later on i fixed this by adding
    $(‘#jqxgrid’).jqxGrid(‘render’);
    But when i add the same command after load the state –
    $(“#jqxgrid”).jqxGrid(‘loadstate’, gridstate);
    it does not show the pinned columns at all.
    thanks for your help
    Load grid state #50534
    mrb9999
    Hi, I’m having this exact same issue. I am using v3.0.3 and when I call “loadstate”, my pinned columns have the appearance of being pinned, but they scroll horizontally as if they are not. Is there an answer for this or is this a defect?
    Paul
    Load grid state #56381
    sofmorona
    i have the same problem… someone could solve it?
    i would be very glad if someone write how to solve it, or if is a bug…
    thank you in advance.
    Load grid state #78979
    maryam_banoo
    Hello
    i have this problem too, on jQWidgets v3.9.1 !
    is there any solution please?
