jQuery UI Widgets › Forums › Gauges and Maps › Gauges › Linear Guage starting at 0 with positive and negative range
Tagged: gauge, jqxLinearGauge, linear gauge, max, min, value
This topic contains 3 replies, has 2 voices, and was last updated by Dimitar 11 years, 11 months ago.
Is it possible to create a linear gauge that ranges from -100 to +100 but the starts from the middle at 0, and either goes forward for positive values or backwards for negative values?
Hello jgaris,
Here is an example:
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxchart.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgauge.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxradiobutton.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxslider.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(), majorTicks = { size: '10%', interval: 10 }, minorTicks = { size: '5%', interval: 2.5, style: { 'stroke-width': 1, stroke: '#aaaaaa'} }, labels = { interval: 20 }; $('#gauge').jqxLinearGauge({ orientation: 'vertical', labels: labels, ticksMajor: majorTicks, ticksMinor: minorTicks, min: -100, max: 100, value: 0, pointer: { size: '6%' }, colorScheme: 'scheme05', ranges: [ { startValue: -10, endValue: 10, style: { fill: '#FFF157', stroke: '#FFF157'} }, { startValue: 10, endValue: 35, style: { fill: '#FFA200', stroke: '#FFA200'} }, { startValue: 35, endValue: 60, style: { fill: '#FF4800', stroke: '#FF4800'}}] }); }); </script> <style type="text/css"> .demo-options { list-style: none; padding: 0px; margin: 10px; } .demo-options li { padding: 3px; font-family: Verdana; font-size: 12px; } </style></head><body class='default'> <div id="gauge" style="margin-left: 20px; float: left;"> </div></body></html>
Thank you for the code, however that was not what I was looking for. In your example the guage bar starts at -100 and you have the value set to 0. I want the guage bar to start at 0, and extend down for negative or extend up from 0 for positive.
Thank you
Hi jgaris,
In the negative case, set the min property to -100 and the max property to 0. In the positive case, set them to 0 and 100 respectively. You may do a check for the value before initializing the widget and set the min and max properties accordingly, i.e.:
var min;var max;if (value >= 0) { min = 0; max = 100;} else { min = -100; max = 0;};$('#gauge').jqxLinearGauge({ // ... min: min, max: max, value: value, // ...});
