jQuery UI Widgets Forums Grid Layout problem
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 5 months ago.
  • Layout problem #49896
    I have a layout issue with the grid which has only begun to happen since I upgraded to the new version. There is a box (obviously a floating div) which extends below and to the right of the actual grid. What css settings should I investigate?
    Also, my pager is no longer showing at the bottom of the grid. Please help.
    S. Staples
    Layout problem #49908
    Hi S. Staples,
    Check whether you have updated the CSS files, too. To use a newer version, you should update the JavaScript & CSS Files.
