jQuery UI Widgets Forums Grid Label-value problem when using combobox in Grid.
This topic contains 13 replies, has 2 voices, and was last updated by  ziyahan 10 years, 11 months ago.
Viewing 14 posts - 1 through 14 (of 14 total)
  • ziyahan
    Hi All;
    We are using combobox in Grid. However, when refocus an element in combobox column, only id shows in it. how can I fix this problem.
    Thanks in advance.
    Hi ziyhan,
    To learn how to create such column, please look this sample: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/gridkeyvaluescolumnwitharray.htm?arctic
    ziyahan
    But this is not combobox. This is dropdownlist element.
    Hi ziyahan,
    The approach is the same. You should change only the columntype. DropDownList and ComboBox are identical widgets with the only difference that ComboBox has Input field, DropDownList has not input field.
    ziyahan
    Hi again,
    Thanks for your answer.
    We create and edit some columns programatically.
    `columns[value[“columnIndex”]].createeditor= function (row, cellvalue, editor) {
    parent.globalEditor = editor;
    editor.jqxComboBox({
    source: value[“elements”],
    displayMember: ‘code’,
    valueMember: ‘id’,
    autoComplete: true,
    enableSelection:true,
    autoOpen:true,
    enableBrowserBoundsDetection:true
    It works, but, when we blur the element, Element shows valueMember, not displayMember.
    ziyahan
    We could not keyboard navigation in dropdownlist, and combobox showed only valueMember when it blured.
    Hi ziyahan,
    You can try it with ComboBox editor in the sample below. It does not change the value on blur. At least in jQWidgets 3.2.1 which is the current version.
        <title id='Description'>In this sample is illustrated how to create a Grid Column with two fields for the cell values and cell labels. Click on a cell in the "Employee Name" column. The cell's label and value will be displayed below the Grid.</title>
                var employeesSource =
                     datatype: "xml",
                         { name: 'FirstName', type: 'string' },
                         { name: 'LastName', type: 'string' }
                     root: "Employees",
                     record: "Employee",
                     url: "../sampledata/employees.xml",
                     async: false
                 var employeesAdapter = new $.jqx.dataAdapter(employeesSource, {
                    autoBind: true,
                        var data = new Array();
                        // update the loaded records. Dynamically add EmployeeName and EmployeeID fields.
                        for (var i = 0; i < records.length; i++) {
                            var employee = records[i];
                            employee.EmployeeName = employee.FirstName + " " + employee.LastName;
                            employee.EmployeeID = employee.uid;
                            data.push(employee);
                        return data;
                var ordersSource =
                    datatype: "xml",
                        // name - determines the field's name.
                        // value - the field's value in the data source.
                        // values - specifies the field's values.
                        // values.source - specifies the foreign source. The expected value is an array.
                        // values.value - specifies the field's name in the foreign source.
                        // values.name - specifies the field's value in the foreign source.
                        // When the ordersAdapter is loaded, each record will have a field called "EmployeeName". The "EmployeeName" for each record comes from the employeesAdapter where the record's "EmployeeID" from orders.xml matches to the "EmployeeID" from employees.xml.
                        { name: 'EmployeeName', value: 'EmployeeID', values: { source: employeesAdapter.records, value: 'EmployeeID', name: 'EmployeeName' } },
                        { name: 'EmployeeID', map: 'm\\:properties>d\\:EmployeeID' },
                        { name: 'ShippedDate', map: 'm\\:properties>d\\:ShippedDate', type: 'date' },
                        { name: 'Freight', map: 'm\\:properties>d\\:Freight', type: 'float' },
                        { name: 'ShipName', map: 'm\\:properties>d\\:ShipName' },
                        { name: 'ShipAddress', map: 'm\\:properties>d\\:ShipAddress' },
                        { name: 'ShipCity', map: 'm\\:properties>d\\:ShipCity' },
                        { name: 'ShipCountry', map: 'm\\:properties>d\\:ShipCountry' }
                    root: "entry",
                    record: "content",
                    url: "../sampledata/orders.xml",
                var ordersAdapter = new $.jqx.dataAdapter(ordersSource);
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    source: ordersAdapter,
                    selectionmode: 'singlecell',
                        { text: 'Employee Name', datafield: 'EmployeeID', displayfield: 'EmployeeName', columntype: 'combobox', width: 150},
                        { text: 'Ship City', datafield: 'ShipCity', width: 150},
                        { text: 'Ship Country', datafield: 'ShipCountry', width: 150 },
                        { text: 'Ship Name', datafield: 'ShipName'}
                $("#jqxgrid").on('cellselect', function (event) {
                    var column = $("#jqxgrid").jqxGrid('getcolumn', event.args.datafield);
                    var value = $("#jqxgrid").jqxGrid('getcellvalue', event.args.rowindex, column.datafield);
                    var displayValue = $("#jqxgrid").jqxGrid('getcellvalue', event.args.rowindex, column.displayfield);
                    $("#eventLog").html("<div>Selected Cell<br/>Row: " + event.args.rowindex + ", Column: " + column.text + ", Value: " + value + ", Label: " + displayValue + "</div>");
                    if (column.displayfield != column.datafield) {
                        $("#eventLog").html("<div>Cell Edited:<br/>Index: " + event.args.rowindex + ", Column: " + column.text + "<br/>Value: " + event.args.value.value + ", Label: " + event.args.value.label
                            + "<br/>Old Value: " + event.args.oldvalue.value + ", Old Label: " + event.args.oldvalue.label + "</div>"
                    else {
                        $("#eventLog").html("<div>Cell Edited:<br/>Row: " + event.args.rowindex + ", Column: " + column.text + "<br/>Value: " + event.args.value
                            + "<br/>Old Value: " + event.args.oldvalue + "</div>"
        <div id='jqxWidget'>
            <div id="jqxgrid">
            <div style="font-size: 13px; margin-top: 20px; font-family: Verdana, Geneva, DejaVu Sans, sans-serif;" id="eventLog"></div>
    ziyahan
    I am sorry. I did not work. We tried same solution. We are using your grid with Knockout together.
    ziyahan
    Peter,
    I am sorry so, I could not tell completely.
    When we create combobox in createeditor function, it works, but the combobox returns id (valueMember, not displayMember) as cellvalue. Cellvalue takes “id” (valueMember of combobox) after cell end edit.
    I think, this is a bug.
    Hi ziyahan,
    That does not happen with the current version. Please, ensure that you use jQWidgets 3.2.1 and not something else.
    ziyahan
    The expected answer thank you Peter.
    It works fine.
    ziyahan
    Hi again;
    I am using latest Jqxwidget version. Same error is occuring still. Please check it.
    Hi ziyahan,
    You may check your initialization code and especially for missing initialization code. If you want an editor to return Label and Value, you should have set displayfield, datafield of your column and you should have created a custom editor and set its displayMember and valueMember and source properties.
    ziyahan
    Peter Hi;
    Thanks for your reply.
    I do such as you said.
    columns[value[“columnIndex”]].createeditor = function (row, cellvalue, editor) {
    valueMember: ‘id’,
    autoComplete: true,
    searchMode: ‘containsignorecase’
