jQuery UI Widgets › Forums › Grid › Knouckout JqxGrid checkbox column not working correctly
This topic contains 1 reply, has 2 voices, and was last updated by Yavor Dashev 3 years, 9 months ago.
I have used an observable array to feed the jqxgrid. but the checkbox column datafield not syncing correctly. grid starting to flicker when I check the checkbox and rows will disappear in the grid. but data is available in the array. Please support to fix this issue
var source = { dataType: "obserableArray", dataFields: [ { name: "WarehousePartition", type: "string" }, { name: "TransactionSelect", type: "bool" }, { name: "RowNum", type: "string" } ], localData: items, id: "RowNum" }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxInternalList").jqxGrid( { source: dataAdapter, altRows: true, sortable: true, width: '100%', theme: 'metro', columnsResize: true, rowsheight: 35, editable: true, columns: [ { text: "", align: "center", dataField: "TransactionSelect", columntype: 'checkbox', width: '3%', cellsAlign: "center", align: "center" }, { text: "Warehouse Partition", align: "center", dataField: "WarehousePartition", width: '10%', cellsAlign: "center", align: "center", editable: false } ] });
Hi Fiham,
I couldn’t reproduce the issue the same way as you have described it that is why I have created a code example which showcases a working checkbox type of a column using the latest version of jQWidgets.
The code example:
<script type="text/javascript"> $(document).ready(function () { var initialData = [ { name: "Well-Travelled Kitten", sales: 352, price: 75.95 }, { name: "Speedy Coyote", sales: 89, price: 190.00 }, { name: "Furious Lizard", sales: 152, price: 25.00 }, { name: "Indifferent Monkey", sales: 1, price: 99.95 }, { name: "Brooding Dragon", sales: 0, price: 6350 }, { name: "Ingenious Tadpole", sales: 39450, price: 0.35 }, { name: "Optimistic Snail", sales: 420, price: 1.50 } ]; var GridModel = function (items) { this.items = ko.observableArray(items); this.disabled = ko.observable(false); this.addItem = function () { // add a new item. if (this.items().length < 20) { this.items.push({ name: "New item", sales: Math.round(Math.random() * 100), price: Math.round(Math.random() * 100) }); } }; this.removeItem = function () { // remove the last item. this.items.pop(); }; this.updateItem = function () { // update the first item. var item = {}; if (initialData.length > 0) { item.name = initialData[Math.floor(Math.random() * initialData.length)].name; item.sales = Math.floor(Math.random() * 500); item.price = Math.floor(Math.random() * 200); this.items.replace(this.items()[0], item); } }; }; ko.applyBindings(new GridModel(initialData)); }); </script> </head> <body class='default'> <div id='jqxWidget'> <div style="margin-bottom: 10px;"> <input id="addButton" type="button" data-bind="click: addItem, jqxButton: {}" value="Add Item" /> <input id="removeButton" type="button" data-bind="click: removeItem, jqxButton: {}" value="Remove Last Item" /> <input id="updateButton" type="button" data-bind="click: updateItem, jqxButton: {}" value="Update First Item" /> <div data-bind="jqxCheckBox: {checked: disabled}" style='margin-top: 5px;' id="checkBox">Disabled</div> </div> <div data-bind="jqxGrid: {source: items, disabled: disabled, autoheight: true, altRows: true, sortable: true, width: '100%', theme: 'metro', columnsResize: true, rowsheight: 35, editable: true, selectionmode: 'singlecell', columns: [ { text: 'Name', dataField: 'name', width: 200, columntype: 'checkbox', }, { text: 'Sales', dataField: 'sales', width: 200, cellsalign: 'right' }, { text: 'Price', dataField: 'price', width: 200, cellsformat: 'c2', cellsalign: 'right' } ]}" id="jqxgrid"> </div> <table style="margin-top: 20px;"> <tbody data-bind="foreach: items"> <tr> <td data-bind="text: name"></td> <td data-bind="text: sales"></td> <td data-bind="text: price"></td> </tr> </tbody> </table> </div>
If you can share a bit more information of how to reproduce the issue or even modify the code snippet that I have sent you then we could be a able to give you a solution for you use case.
Yavor Dashev
https://www.jqwidgets.com -
