jQuery UI Widgets › Forums › Grid › Kindly help jqx filterable feature is not working with virtual paging.
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 12 years, 7 months ago.
January 8, 2013 at 12:57 pm Kindly help jqx filterable feature is not working with virtual paging. #13286
Hello All,
I just modified virtual data paging to include filterable feature. But it doesn’t filer if I enter anything in filter textboxes below each column.
Could you kindly help me fix this please? Below is my code.
Thanks so much!
var data = new Array();
var jsonObject = { “contactList”:[
{“age”:1,”SId”:”S1234567″,”gender”:”male”},
{“age”:1,”SId”:”S1234567″,”gender”:”male”},], “totalrecords”:2};
var generatedata = function (startindex, endindex) {
var data = {};
for (var i = startindex; i < endindex; i++) {
var row = {};
if (jsonObject.contactList[i]) {
row["age"] = jsonObject.contactList[i].age;
row["gender"] = jsonObject.contactList[i].gender;
row["SId"] = jsonObject.contactList[i].SId;
data[i] = row;
return data;
datatype: "array",
localdata: {},
totalrecords: jsonObject.totalrecords
// load virtual data.
var data = generatedata(params.startindex, params.endindex);
return data;
var totalcolumnrenderer = function (row, column, cellvalue) {
var cellvalue = $.jqx.dataFormat.formatnumber(cellvalue, 'c2');
return '‘ + cellvalue + ”;
$(“#jqxgrid”).jqxGrid(
width: 670,
virtualmode: true,
showfilterrow: true,
{ text: ‘Age’, datafield: ‘age’, width: 50 },
{ text: ‘SId’, datafield: ‘SId’, width: 120 },
{ text: ‘Gender’, datafield: ‘gender’, width: 80 },
});January 8, 2013 at 1:10 pm Kindly help jqx filterable feature is not working with virtual paging. #13290Hi Zafar,
In virtual mode, the Grid’s data is loaded on demand in the Grid, so the local filtering will not work as there are records only in the view. See this sample for filtering implementation in virtual mode: serverfiltering_paging_and_sorting.htm.
