jQuery UI Widgets Forums Grid Kindly help, data is not being displayed in virtual paging.
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 6 months ago.
  • Zafar
    Hi!
    <html lang=”en”>
    <title id=’Description’>In this demo jqxGrid uses a virtualized paging which enables you to handle very large data sets without any impact on client side performance.</title>
    <script type=”text/javascript” src=”../../scripts/jquery-1.8.2.min.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.pager.js”></script>
    <script type=”text/javascript” src=”../../scripts/gettheme.js”></script>
    var theme = getTheme();
    var data = new Array();
    var jsonObject = { “contactList”:[
    {“age”:1,”SId”:”S1234567″,”gender”:”male”},
    ], “totalrecords”:9};
    //alert(“jsonObject.totalrecords : ” + jsonObject.totalrecords);
    // generate sample data.
    var generatedata = function (startindex, endindex) {
    var data = {};
    for (var i = startindex; i < endindex; i++) {
    //alert(startindex + ” ” + endindex);
    var row = {};
    row[“age”] = jsonObject.contactList[i].age;
    row[“gender”] = jsonObject.contactList[i].gender;
    row[“SId”] = jsonObject.contactList[i].SId;
    data[i] = row;
    return data;
    datatype: “array”,
    localdata: {},
    totalrecords: jsonObject.totalrecords
    // load virtual data.
    alert(“rendergridrows : ” + source.totalrecords);
    //alert(“rendergridrows : ” + params.startindex + ” ” + params.endindex);
    var data = generatedata(params.startindex, params.endindex);
    return data;
    var totalcolumnrenderer = function (row, column, cellvalue) {
    var cellvalue = $.jqx.dataFormat.formatnumber(cellvalue, ‘c2’);
    return ‘<span style=”margin: 6px 3px; font-size: 12px; float: right; font-weight: bold;”>’ + cellvalue + ‘</span>’;
    $(“#jqxgrid”).jqxGrid(
    width: 670,
    virtualmode: true,
    { text: ‘Age’, datafield: ‘age’, width: 50 },
    { text: ‘SId’, datafield: ‘SId’, width: 120 },
    { text: ‘Gender’, datafield: ‘gender’, width: 80 },
    <body class=’default’>
    <div id=’jqxWidget’ style=”font-size: 13px; font-family: Verdana; float: left;”>
    <div id=”jqxgrid”></div>
    Hi Zafar,
    Here’s updated and working code:
    var jsonObject = { "contactList":[
    {"age":1,"SId":"S1234567","gender":"male"},
    ], "totalrecords":9};
    var data = {};
    var row = {};
    if (jsonObject.contactList[i]) {
    row["age"] = jsonObject.contactList[i].age;
    row["gender"] = jsonObject.contactList[i].gender;
    row["SId"] = jsonObject.contactList[i].SId;
    data[i] = row;
    return data;
    datatype: "array",
    localdata: {},
    return data;
    var cellvalue = $.jqx.dataFormat.formatnumber(cellvalue, 'c2');
    return '<span style="margin: 6px 3px; font-size: 12px; float: right; font-weight: bold;">' + cellvalue + '</span>';
    $("#jqxgrid").jqxGrid(
    width: 670,
    virtualmode: true,
    { text: 'Age', datafield: 'age', width: 50 },
    { text: 'SId', datafield: 'SId', width: 120 },
    { text: 'Gender', datafield: 'gender', width: 80 },
    <div id='jqxWidget'>
    <div id="jqxgrid">
