jQuery UI Widgets Forums General Discussions JqxWidget JS upgradation problem
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 7 months ago.
  • JqxWidget JS upgradation problem #46431
    fearbuster
    Currently i am using older version JQx JS. But some additional functionality, i am moved to upgrade that js like checkall etc.
    If am upgrading ,it killed my previous code like grid can’t load properly.
    Please help me what i do for that problem, please solve my this issue.
    JqxWidget JS upgradation problem #46433
    Hi fearbuster,
    Unfortunately, the provided information does not bring much details. I would suggest you to check the Release Notes, because there are some breaking changes and also to check the documentation about the API that you use and enable the debugger of your browser. If there are errors in the migration due to the stricter validation about incorrect usage of API, they would be displayed on your debugger’s console window.
