jQuery UI Widgets Forums General Discussions Navigation Tree jqxTree with checkboxes using KnockoutJS
This topic contains 7 replies, has 3 voices, and was last updated by  Makla 12 years, 4 months ago.
  • jqxTree with checkboxes using KnockoutJS #14113
    lepa
    Hi all, I’m trying to create a jqxTree with checkboxes that is databound using KnockoutJS but I can’t get the checkboxes shown. Can you provide a quick example like the one in the demos? Thanks
    jqxTree with checkboxes using KnockoutJS #14116
    Hi lepa,
    To show checkboxes in jqxTree, you should set its “checkboxes” property to true and also to include the jqxcheckbox.js file into your page.
    jqxTree with checkboxes using KnockoutJS #14117
    lepa
    Thanks Peter, for a normal jqxTree this works. but for one that is connected to knockout the checkboxes are not shown…
    jqxTree with checkboxes using KnockoutJS #14118
    Hi lepa,
    Here’s a sample:
    <title id="Description">Integration of jqxTree with Knockout</title>
    <script type="text/javascript" src="../../scripts/jquery-1.9.0.min.js"></script>
    <script type="text/javascript" src="../../scripts/json2.js"></script>
    <script type="text/javascript" src="../../scripts/knockout-2.1.0.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxknockout.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script>
    // Define a "Person" class that tracks its own name and children, and has a method to add a new child
    var Person = function (name, items) {
    this.label = name;
    this.items = ko.observableArray(items);
    this.enabled = ko.observable(true);
    this.addItem = function () {
    if (this.items().length < 4) {
    this.items.push("New Item");
    else if (this.items().length == 4) {
    this.items.push("Last Item");
    this.enabled(false);
    // The view model is an abstract description of the state of the UI, but without any knowledge of the UI technology (HTML)
    var viewModel = {
    people: [
    new Person("Annabelle", ["Arnie", "Anders", "Apple"]),
    new Person("Bertie", ["Boutros-Boutros", "Brianna", "Barbie", "Bee-bop"]),
    new Person("Charles", ["Cayenne", "Cleopatra"])
    disabled: ko.observable(false)
    $("#tree").jqxTree({ checkboxes: true });
    ko.applyBindings(viewModel);
    $("#tree").jqxTree('expandAll');
    <body style='font-size: 13px; font-family: Verdana;' class='default'>
    <div>
    <div style="float: left;">
    <ul data-bind="foreach: people">
    <li>
    <div>
    <span data-bind="text: label"></span><a href='#' data-bind='click: addItem, visible: enabled'> Add Item</a>
    <ul data-bind="foreach: items">
    <li><span data-bind="text: $data"></span></li>
    </ul>
    </li>
    </ul>
    <div style="float: left; margin-left: 50px;">
    <div data-bind="jqxTree: {source: people, disabled: disabled, theme: getDemoTheme()}" id="tree">
    <div data-bind="jqxCheckBox: {checked: disabled, theme: getDemoTheme()}" style='margin-top: 5px;' id="checkBox">Disabled</div>
    jqxTree with checkboxes using KnockoutJS #14150
    lepa
    Thanks Peter,
    your code is working 🙂 However would it be possible to add a new property in Person like:
    this.checked = ko.observable(true);
    and then use it to get the value of the corresponding checkbox?
    I’ve tried it but when I try to retrieve the value it is always false…
    jqxTree with checkboxes using KnockoutJS #14164
    Hi lepa,
    That will not be possible at present. We will consider updating this in the future versions. Thanks for the feature request.
    jqxTree with checkboxes using KnockoutJS #14176
    lepa
    Is there a quick & dirty solution I can do? or does this need some major development…? My tree will only have 2 levels.
    Makla
    your code is working However would it be possible to add a new property in Person like:
    This would be a really nice feature. +1 vote
