jQuery UI Widgets › Forums › Navigation › Tree › jqxtree, model is incorrect after deleting node.
This topic contains 14 replies, has 3 voices, and was last updated by Jazz 11 years, 11 months ago.
Hi jqwidget team.
I found some problem after deleting node on jqxtree.
please take a look in my simple code. there are 5 nodes showing on jqxtree. where I add new node by click buttom “Get all Items” , model is added correctly but when I remove some node. model is not deleted as It should be. It seems like I have to add new node if I want to refresh model.
please help me.
<!DOCTYPE html><html lang="en"><head> <title></title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../scripts/knockout-2.2.1.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxknockout.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdragdrop.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript"> $(document).ready(function () { var Menu = function (id, name, items) { this.value = id; this.label = name; this.items = ko.observableArray(items); this.dataroot = ko.observable(""); } var viewModel = { people: [ new Menu(1, "Account"), new Menu(2, "Agent"), new Menu(3, "Customer"), new Menu(4, "Claim"), new Menu(5, "Report") ], id: ko.observable(""), value: ko.observable(""), label: ko.observable(""), parentId: ko.observable(""), level: ko.observable(""), additem: ko.observable("") }; $('#jqxTree').on('select', function (event) { var args = event.args; var item = $('#jqxTree').jqxTree('getItem', args.element); if (item) { viewModel.id(item.id); viewModel.value(item.value); viewModel.label(item.label); viewModel.parentId(item.parentId); viewModel.level(item.level); } }); $("#jqxTree").on('dragStart', function (event) { $("#Event").text("Drag Start: " + event.args.label); }); $("#jqxTree").on('dragEnd', function (event) { $("#Event").text("Drag End"); }); // Create and initialize Buttons $('#Add, #Remove, #Get').jqxButton({ height: '25px', width: '100px' }); // Add $('#Add').click(function () { var selectedItem = $('#jqxTree').jqxTree('selectedItem'); if (selectedItem != null) $('#jqxTree').jqxTree('addTo', { label: viewModel.additem() }, selectedItem.element, false); else $('#jqxTree').jqxTree('addTo', { label: viewModel.additem() }, null, false); $('#jqxTree').jqxTree('render'); }); // Remove $('#Remove').click(function () { var selectedItem = $('#jqxTree').jqxTree('selectedItem'); if (selectedItem != null) { $('#jqxTree').jqxTree('removeItem', selectedItem.element, false); $("#jqxTree").jqxTree('selectItem', null); $('#jqxTree').jqxTree('render'); } $('#jqxTree').jqxTree('refresh'); }); // Get all Items $('#Get').click(function () { var items = $('#jqxTree').jqxTree('getItems'); if (items != null) { $("#Event").text("Menu Data: " + items); alert(items.length); //alert(items[2].label); } }); ko.applyBindings(viewModel); }); </script></head><body> <div style='float: left; margin-left: 20px; border: none;' data-bind="jqxTree: { allowDrag: true, allowDrop: true, source: people, height: '540px', width: '350px'}" id="jqxTree"></div> <div style='margin-left: 60px; float: left;'> <div style='margin-top: 10px;'> ID: <input type="text" data-bind="value: id" /> </div> <div style='margin-top: 10px;'> ParentID: <input type="text" data-bind="value: parentId" /> </div> <div style='margin-top: 10px;'> ServerID: <input type="text" data-bind="value: value" /> </div> <div style='margin-top: 10px;'> Label: <input type="text" data-bind="value: label" /> </div> <div style='margin-top: 10px;'> Level: <input type="text" data-bind="value: level" /> </div> <div style='margin-top: 10px;'> <input type="button" id='Add' value="Add" /> <input type="text" data-bind="value: additem" /> </div> <div style='margin-top: 10px;'> <input type="button" id='Remove' value="Remove" /> </div> <div style='margin-top: 10px;'> <input type="button" id='Get' value="Get all Items" /> </div> </div> <div id="Event"></div></body></html>
I do not see a code for deleting an item from the model.
http://www.jqwidgets.comHi,
Im Sorry, I wrote wrong.
“Add” is for adding an item. input some text into the next textbox.
“Remove” is for removing an item which is selected.
“Get all Items” for alert model.legth and display all model on the right side.please add an item. then click button “Get all Items” you will see item.length is correct.
but if you click “Remove” and then click “Get all Items” again. you will see item.length is incorrect untill you add new item againThe problem is after delete an item. Your function $(‘#jqxTree’).jqxTree(‘getItems’); does not get total item correctly.
Why don’t you use viewModel.people().length?
Thank you for keep talking with me.
Im just realized that items on jqxtree is not related to my model. it is just loaded on the first time.
I know when I use command $(‘#jqxTree’).jqxTree(‘addTo’, { label: “Select” }, selectedItem.element, false);
or $(‘#jqxTree’).jqxTree(‘removeItem’, selectedItem.element, false); my model is not changed following by jqxtree item.so, I have no choice except using $(‘#jqxTree’).jqxTree(‘getItems’); to refresh jqxtree item correctly.
please help me to fine a way out.
here is my new example.
<!DOCTYPE html><html lang="en"><head> <title></title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdragdrop.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript"> $(document).ready(function () { var data = [ { "id": "5", "parentid": "1", "text": "White Hot Chocolate", "value": "$2.3" }, { "text": "Chocolate Beverage", "id": "1", "parentid": "-1", "value": "$2.3" }, { "id": "6", "text": "Espresso Beverage", "parentid": "-1", "value": "$2.3" }, { "id": "11", "text": "Pumpkin Spice Latte", "parentid": "6", "value": "$2.3" }, { "id": "12", "text": "Frappuccino", "parentid": "-1" }, { "id": "13", "text": "Caffe Vanilla Frappuccino", "parentid": "12", "value": "$2.3" }, { "id": "15", "text": "450 calories", "parentid": "13", "value": "$2.3" }, { "id": "16", "text": "16g fat", "parentid": "13", "value": "$2.3" }, { "id": "17", "text": "13g protein", "parentid": "13", "value": "$2.3" }, { "id": "14", "text": "Caffe Vanilla Frappuccino Light", "parentid": "12", "value": "$2.3" }] // prepare the data var source = { datatype: "json", datafields: [ { name: 'id' }, { name: 'parentid' }, { name: 'text' }, { name: 'value' } ], id: 'id', localdata: data }; var dataAdapter = new $.jqx.dataAdapter(source); dataAdapter.dataBind(); var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'text', map: 'label'}]); $('#jqxTree').jqxTree({ allowDrag: true, allowDrop: true, source: records, height: '540px', width: '350px' }); $('#jqxTree').on('select', function (event) { var args = event.args; var item = $('#jqxTree').jqxTree('getItem', args.element); if (item) { $("#id").val(item.id); $("#value").val(item.value); $("#label").val(item.label); $("#parentId").val(item.parentId); $("#level").val(item.level); } }); $("#jqxTree").on('dragStart', function (event) { $("#Event").text("Drag Start: " + event.args.label); }); $("#jqxTree").on('dragEnd', function (event) { $("#Event").text("Drag End"); }); // Create and initialize Buttons $('#Add, #Get').jqxButton({ height: '25px', width: '180px' }); $('#Remove').jqxButton({ height: '30px', width: '300px' }); // Add $('#Add').click(function () { var selectedItem = $('#jqxTree').jqxTree('selectedItem'); if (selectedItem != null) $('#jqxTree').jqxTree('addTo', { label: "Select" }, selectedItem.element, false); else $('#jqxTree').jqxTree('addTo', { label: "Unselect" }, null, false); $('#jqxTree').jqxTree('render'); }); // Remove $('#Remove').click(function () { var selectedItem = $('#jqxTree').jqxTree('selectedItem'); if (selectedItem != null) { $('#jqxTree').jqxTree('removeItem', selectedItem.element, false); $("#jqxTree").jqxTree('selectItem', null); $('#jqxTree').jqxTree('render'); } }); // Get all Items $('#Get').click(function () { var items = $('#jqxTree').jqxTree('getItems'); if (items != null) { $("#Event").text(items); alert('MyData:' + data.length + ', jqxTreeitem:' + items.length); } }); $('#jqxTree').jqxTree('expandAll'); }); </script></head><body> <div style='float: left; margin-left: 20px; border: none;' id="jqxTree"></div> <div style='margin-left: 60px; float: left;'> <div style='margin-top: 10px;'> ID: <input type="text" id="id" /> </div> <div style='margin-top: 10px;'> ParentID: <input type="text" id="parentId" /> </div> <div style='margin-top: 10px;'> Value: <input type="text" id="value" /> </div> <div style='margin-top: 10px;'> Label: <input type="text" id="label" /> </div> <div style='margin-top: 10px;'> Level: <input type="text" id="level" /> </div> <div style='margin-top: 10px;'> <input type="button" id='Add' value="Add Item to jqxTree" /> </div> <div style='margin-top: 10px;'> <input type="button" id='Remove' value="REMOVE SELECTED ITEM!!" /> </div> <div style='margin-top: 10px;'> <input type="button" id='Get' value="Get all DATA in jqxTree" /> </div> </div> <div id="Event"></div></body></html>
Hi Peter Stove
Im still looking forward to getting answer from you. Im quite sure. This is a bug.
I have tested by using on jqwidget 2.9. the result is still same, getting incorrect items.
Please give me your advice.
Thank you.
1. The following sample shows how to use jqxTree with KO: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxknockout/tree.htm?web.
2. The jqxTree’s addTo, removeItem, etc. methods will not update your KO model as these are not exposed as observables.
Please use my secord simple code above for your test.
There is no ko model on this code. There is just only jqx command on it.
I use jqx command
$(‘#jqxTree’).jqxTree(‘addTo’, { label: “Select” }, selectedItem.element, false); to add item into jqxtree
and command
$(‘#jqxTree’).jqxTree(‘removeItem’, selectedItem.element, false); to remove item out.
after adding item. the command $(‘#jqxTree’).jqxTree(‘getItems’); works well. it gets items correctly.
but
after remove item. the command $(‘#jqxTree’).jqxTree(‘getItems’); works wrong. it gets incorrect items like not refreshed. please see the item total amount, that included a deleted items.
If I got correct items by $(‘#jqxTree’).jqxTree(‘getItems’) after adding item, it should be correct after removing item as well.
Anyway, thank you very much for your response.
“addTo” and “removeItem” will not synchronize the Tree Items with your KO Model.
You don’t understand my point. I said, there is no ko model in my code. and I have already known that it doesnt synchronize with ko model.
Tree Items is wrong. It is not the ko model.
please take a look at code below. I have to fix it by myself. It should be correct since I get items by using your function $(‘#jqxTree’).jqxTree(‘getItems’);
var deletelist = new Array(); deletelist[0] = selectedItem.id; var level_p = 0; var check_p = false; for (var i = 0; i < items.length; i++) { if (check_p == false) { if (selectedItem.id == items[i].id) { check_p = true; level_p = items[i].level; } } else { if (items[i].level == level_p) { break; } deletelist[deletelist.length] = items[i].id; } } var itempp = $('#jqxTree').jqxTree('getItems'); for (var i = 0; i < deletelist.length; i++) { var indexp = itempp.indexOf(deletelist[i]); itempp.remove(indexp); }
Correct me if I understand it wrong. The issue is that “getItems” returns wrong results after removing items?
Looking forward to your reply.
Yes it is, thank you’re already get it this issue just like this topic
http://www.jqwidgets.com/community/topic/removing-items-from-jqxtree/#post-10274
Thank you.
I can confirm this as well as I just hit this exact same problem.
I have a tree list that gets updated with new items and has items removed. I also have a ‘counter’ that displays the number of items in the tree. (we’re processing inbound document queues).
I get the number of items like so:
var itemCount = $('#doclist').jqxTree('getItems').length;
After removing an item from the tree and executing the above line of code again, the value does not change. Further investigation shows that the array of items returned by getItems() still contains the items that I removed with removeItem() even though the items are removed from the list correctly.
Jamie
There is no such issue in the current version(jQWidgets 2.9.2). All items are removed correctly and getItems method returns correct results.
http://www.jqwidgets.comAh ha! Didn’t realise I was still on 2.8.3 on this system.
Yes, 2.9.2 does not have this problem. Simply updating the jqWidgets libs fixed my problem.
Thanks Peter.
