jQuery UI Widgets Forums Navigation Tree JQXTREE ISSUE
This topic contains 5 replies, has 2 voices, and was last updated by  Harsh 9 years, 7 months ago.
  • JQXTREE ISSUE #76341
    Harsh
    Hello ,
    I ran into a weird scenario of jq tree.
    Below is what am i trying to achieve
    :- I have a requirement where i need to fill the tree on demand .
    For this i am using the pattern which was stated in demo of jqxtree.
    Now somewhere downside of the tree sub node, on expand , i am about to get around 6500 sub leaf . This is where am stuck
    $(‘#treeviewProperty’).jqxTree(‘addTo’, childData, $element[0])
    For tree having around 50 sub nodes, its working fine.
    BUT , Where childData is having array of 6500 elements in it. When this line gets hit , i am getting error of UNRESPONSIVE SCRIPT .
    Also , this
    Jqx Tree Unresponsive
    issue is happening on I-3 64bit windows 7 ,
    On I-5 machine, tree is taking time to load, but not giving error of UNRESPONSIVE Script..
    Any Help is really appreciated.
    Harsh G
    JQXTREE ISSUE #76365
    ivailo
    Hi harsh.gulati,
    This behavior depends from the available system resources.
    To avoid it, we offer you to use another widget – jqxTreeGrid.
    jqxTreeGrid allows virtual mode, so you can populate it with bigger data sources.
    Here is the demo.
    Ivailo Ivanov
    JQXTREE ISSUE #76424
    Harsh
    Hello ivailo,
    Thanks for the suggestion , before i go for this implementation , will it be serving the way i am trying to develop the tree.
    Steps as follow:-
    on load , i am getting the root node json from a webservice call & binding it to treehtml element .
    now on expand , i am making a on ajax post to other webservice call , get subnode & fill it again inside the expanded node..
    Note:- I am not getting the whole json of tree & its respective subnode & leafs on load of document/html page. rather i am doing on request load
    Is this available in JqxTreeGrid
    Kindly advice on this as well.
    Harsh
    JQXTREE ISSUE #76425
    Harsh
    Drag/drop feature is also required. So will the jqxtreegrid serve all such features ?
    JQXTREE ISSUE #76454
    ivailo
    Hi Harsh,
    You can try this demo with request.
    About Drag and Drop you can use plugin. jqxTreeGrid is very similar to jqxGrid, so as an example you can see this demo. Unfortunately rows reorder is not supported.
    Ivailo Ivanov
    JQXTREE ISSUE #76781
    Harsh
    Thanks so much ivailo.
