jQuery UI Widgets Forums Navigation Tabs jqxTabs control breaks other controls
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 7 months ago.
  • jqxTabs control breaks other controls #33138
    Yuri Antipin
    Hi!
    The jqxTabs control breaks the jqxDateTimeInput and jqxComboBox when they placed into jqxWindow.
    Browser: any
    My example is here:
    <meta charset="utf-8" />
    <title> </title>
    <link rel="stylesheet" href="styles/jqx.base.css"/>
    <script type="text/javascript" src="scripts/jquery-1.10.2.min.js"> </script>
    <script type="text/javascript" src="scripts/jqx-all.js"> </script>
    function createWindow(tabs, input, combobox) {
    $('#form').jqxWindow({
    height: 400,
    width: 400,
    title: '',
    resizable: true,
    initContent: function () {
    $('#form').find('.jqx-window-content')
    .append(input.jqxDateTimeInput({ width: '100%' }))
    .append(combobox.jqxComboBox({ width: '100%' }))
    .append(tabs.jqxTabs({ width: 300, height: 200 }));
    var tabs = $('<div><ul><li>First tab</li><li>Second tab</li></ul><div></div><div></div></div>');
    var input = $('<div>').css('margin-bottom', 5);
    var combobox = $('<div>').css('margin-bottom', 5);
    createWindow(tabs, input, combobox);
    <body>
    <div id="form"><div></div></div>
    jqxTabs control breaks other controls #33143
    Hi Yuri Antipin,
    The initialization is missing some required files like globalize.js and also for creating jqxTabs and using it along with other widgets, you may look at the http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxtabs/integration.htm?arctic
    jqxTabs control breaks other controls #33147
    Yuri Antipin
    Hi Peter Stoev,
    It is just a simple example that demonstrates the bug.
    My temporary solution:
    input.jqxDateTimeInput({ width: '100%' });
    combobox.jqxComboBox({ width: '100%' });
    tabs.jqxTabs({ width: 300, height: 200 });
    height: 400,
    width: 400,
    title: '',
    resizable: true,
    .append(input)
    .append(combobox)
    .append(tabs);
    In this example everything works correctly. Why I can’t use the inline code?
    Yuri Antipin
    jqxTabs control breaks other controls #33148
    Hi Yuri,
    Widgets should be initialized from HTML elements which are part of the DOM. The posted code creates widgets in reversed order – you initialize them from HTML which is outside the DOM and after that you add the HTML to the DOM.
    Here’s an update from me:
    height: 400,
    width: 400,
    title: 'Some Title',
    resizable: true,
    .append(input)
    .append(combobox)
    .append(tabs);
    input.jqxDateTimeInput({ width: 300 });
    combobox.jqxComboBox({ width: 300 });
