jQuery UI Widgets Forums Plugins AngularJS jqxtabs-angularJS Issue
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 9 years, 2 months ago.
  • jqxtabs-angularJS Issue #82563
    Keshavan
    I had issue using jqx-validator, jqx-input and jqx-passwordinput with in angular SPA and it didn’t work for <div ng-view></div> in index page. I then changed <div ng-view></div> to <ng-view></ng-view> in index.html. It then rendered the corresponding html page (authEnticate.html) with the above jqx controls.
    Now i have problem rendering html page (custMaterials.html) with jqx-tabs with in <ng-view></ng-view> of my index.html page. It just displays the content and not the tabs.
    Please find the code below.
    Keshavan
    index.html
    <html ng-app="mainApp" lang="en">
        <title id='Description'>The demo demonstrates the Minimized state of jqxMenu.</title>
        <link rel="stylesheet" type="text/css" href="/angularjs/jQWidgets/jqwidgets/styles/jqx.base.css" />
        <script type="text/javascript" src="/angularjs/jQWidgets/scripts/jquery-1.11.1.min.js"></script>
        <script src="//ajax.googleapis.com/ajax/libs/angularjs/1.3.15/angular.min.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcore.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxangular.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxmenu.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcheckbox.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxtabs.js"></script>
        <script src="//angular-ui.github.io/ui-router/release/angular-ui-router.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/mainApp.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/authApp.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/demoApp1.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/menuController.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/mainCtrl.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxvalidator.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/authController.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxdata.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxinput.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxpasswordinput.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/register.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/logIn.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/logOut.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/scripts/demos.js"></script>
        <script src="https://cdn.firebase.com/js/client/2.2.4/firebase.js"></script>
        <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/globalization/globalize.js"></script>
        <script src="https://cdn.firebase.com/libs/angularfire/1.1.3/angularfire.min.js"></script>
    <body ng-controller="mainCtrl">
        <div ng-controller="menuController">
            <jqx-menu jqx-on-itemclick="itemclick(event)" jqx-settings="menuSettings">
                <ul>
                    <li><a ui-sref="Quotations">Quotations</a></li>
                    <li><a ui-sref="Messages">Messages</a></li>
                    <li><a ui-sref="Logout">Logout</a></li>
                </ul>
            </jqx-menu>
            <jqx-check-box ng-model="checked " ng-change="changeState($event) ">Minimized</jqx-check-box>
            <br/>
            <ui-view></ui-view>
    authEnticate.html
    <html ng-app="authApp" lang="en">
        <title id="Description">jqxInput directive for AngularJS</title>
    <body>
            <form jqx-validator jqx-settings="validatorSettings">
                <jqx-input ng-model="email" jqx-width="200" jqx-height="25" id="emailInput" placeholder="'Enter your eMail Id'"> </jqx-input>{{email}}
                <br />
                <br />
                <jqx-password-input ng-model="password" jqx-width="200" jqx-height="25" type="password" placeholder="'Enter your Password'" id="passwordInput"></jqx-password-input>
                <br />
                <jqx-toggle-button jqx-settings="settings" ng-click="register()">register</jqx-toggle-button>
                <jqx-toggle-button jqx-settings="settings" ng-click="logIn()">logIn</jqx-toggle-button>
                <jqx-toggle-button jqx-settings="settings" ng-click="logOut()">logOut</jqx-toggle-button>
            </form>
        <div ng-if="error" <strong> error !! {{error}}</strong>
        <div ng-if="authData" <strong> success !! UID : {{ authData.uid }}</strong>
    custMaterials.html
    <html ng-app>
        <title id="Description">jqxTabs Directive for AngularJS</title>
        <meta name="description" content="AngularJS Tabs example. This demonstrates Tabs widget built with AngularJS" />
        //    var demoApp1 = angular.module("demoApp1", ["jqwidgets"]);
            angular.module("demoApp1").controller("demoController1", function ($scope) {
                var people = new Array();
                var firstNames = ["Bed Room", "Living", "Dining", "Kitchen", "Children", "Sitout", "Bath Room" ,"Car", "Bike"];
                var lastNames = ["Davolio", "Fuller", "Leverling", "Peacock", "Buchanan", "Suyama", "King", "Callahan", "Dodsworth"];
                var titles = ["Sales Representative", "Vice President, Sales", "Sales Representative", "Sales Representative", "Sales Manager", "Sales Representative", "Sales Representative", "Inside Sales Coordinator", "Sales Representative"];
                var titleofcourtesy = ["Ms.", "Dr.", "Ms.", "Mrs.", "Mr.", "Mr.", "Mr.", "Ms.", "Ms."];
                var birthdate = ["08-Dec-48", "19-Feb-52", "30-Aug-63", "19-Sep-37", "04-Mar-55", "02-Jul-63", "29-May-60", "09-Jan-58", "27-Jan-66"];
                var hiredate = ["01-May-92", "14-Aug-92", "01-Apr-92", "03-May-93", "17-Oct-93", "17-Oct-93", "02-Jan-94", "05-Mar-94", "15-Nov-94"];
                var address = ["507 - 20th Ave. E. Apt. 2A", "908 W. Capital Way", "722 Moss Bay Blvd.", "4110 Old Redmond Rd.", "14 Garrett Hill", "Coventry House", "Miner Rd.", "Edgeham Hollow", "Winchester Way", "4726 - 11th Ave. N.E.", "7 Houndstooth Rd."];
                var city = ["Seattle", "Tacoma", "Kirkland", "Redmond", "London", "London", "London", "Seattle", "London"];
                var postalcode = ["98122", "98401", "98033", "98052", "SW1 8JR", "EC2 7JR", "RG1 9SP", "98105", "WG2 7LT"];
                var country = ["USA", "USA", "USA", "USA", "UK", "UK", "UK", "USA", "UK"];
                var homephone = ["(206) 555-9857 FREE", "(206) 555-9482 FREE", "(206) 555-3412 FREE", "(206) 555-8122 FREE", "(71) 555-4848", "(71) 555-7773", "(71) 555-5598", "(206) 555-1189 FREE", "(71) 555-4444"];
                for (var i = 0; i < firstNames.length; i++) {
                    var row = {};
                    row["firstname"] = firstNames[i];
                    row["lastname"] = lastNames[i];
                    row["title"] = titles[i];
                    row["titleofcourtesy"] = titleofcourtesy[i];
                    row["birthdate"] = birthdate[i];
                    row["hiredate"] = hiredate[i];
                    row["address"] = address[i];
                    row["city"] = city[i];
                    row["postalcode"] = postalcode[i];
                    row["country"] = country[i];
                    row["homephone"] = homephone[i];
          //          row["url"] = "../../../images/" + firstNames[i].toLowerCase() + ".png";
                    people[i] = row;
                $scope.people = people;
    <body>
        <div>
            <jqx-tabs jqx-width="'800px'" jqx-height="'200px'">
                <ul>
                    <li style="margin-left: 30px;">{{people[0].firstname}}</li>
                    <li>{{people[1].firstname}}</li>
                    <li>{{people[2].firstname}}</li>
                    <li>{{people[3].firstname}}</li>
                    <li>{{people[4].firstname}}</li>
                    <li>{{people[5].firstname}}</li>
                    <li>{{people[6].firstname}}</li>
                    <li>{{people[7].firstname}}</li>
                    <li>{{people[8].firstname}}</li>
                </ul>
                <div>
                   <div style="margin: 15px;">
                        <div style="float: left; width: 15%;">
                            <div class='jqx-rc-all' style='margin: 10px;'><b>Photo:</b></div>
                            <div style='margin-top: 10px;'>
                                <img height="60" ng-src={{people[0].url}}>
                        <div style="float: left; width: 45%;">
                            <div style='margin: 10px;'><b>First Name:</b>{{people[0].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[0].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[0].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[0].address}}</div>
                        <div style="float: left; width: 40%;">
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[0].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[0].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[0].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[0].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[1].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[1].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[1].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[1].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[1].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[1].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[1].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[1].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[1].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[2].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[2].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[2].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[2].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[2].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[2].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[2].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[2].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[2].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[3].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[3].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[3].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[3].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[3].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[3].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[3].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[3].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[3].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[4].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[4].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[4].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[4].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[4].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[4].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[4].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[4].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[4].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[5].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[5].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[5].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[5].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[5].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[5].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[5].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[5].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[5].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[6].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[6].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[6].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[6].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[6].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[6].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[6].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[6].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[6].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[7].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[7].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[7].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[7].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[7].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[7].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[7].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[7].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[7].hiredate}}</div>
                <div>
                                <img height="60" ng-src={{people[8].url}}>
                            <div style='margin: 10px;'><b>First Name:</b>{{people[8].firstname}}</div>
                            <div style='margin: 10px;'><b>Last Name:</b>{{people[8].lastname}}</div>
                            <div style='margin: 10px;'><b>Title:</b>{{people[8].title}}</div>
                            <div style='margin: 10px;'><b>Address:</b>{{people[8].address}}</div>
                            <div style='margin: 10px;'><b>Postal Code:</b>{{people[8].postalcode}}</div>
                            <div style='margin: 10px;'><b>City:</b>{{people[8].city}}</div>
                            <div style='margin: 10px;'><b>Phone:</b>{{people[8].homephone}}</div>
                            <div style='margin: 10px;'><b>Hire Date:</b>{{people[8].hiredate}}</div>
             </jqx-tabs>
    jqxtabs-angularJS Issue #82567
    Keshavan
    jQWidgets version 4.0
    Keshavan
    jqxtabs-angularJS Issue #82572
    Keshavan
    ISSUE SORTED, PLEASE IGNORE POST
    jqxtabs-angularJS Issue #82575
    Hi Keshavan,
    Could you post the solution for the benefit of the others in the forum?
    Peter
