jQuery UI Widgets Forums ASP .NET MVC jqxtab inside jqxwindow behaving strange
This topic contains 2 replies, has 2 voices, and was last updated by  RobWarning 7 years, 5 months ago.
  • jqxtab inside jqxwindow behaving strange #98659
    RobWarning
    I have in a mvc application a jqx window with an jqx tab inside like this:
     $('#addComplaint').click(function () {
            $('#AddNewWindow').jqxWindow({
                theme: 'energyblue',
                title: 'Add new complaint',
                isModal: true,
                initContent: function () {
                    $('#tabs').jqxTabs({
                        collapsible: true
                    $('#AddnewDiv').empty();
                    $('#AddnewDiv').load("/Home/GetView", { ViewName: "_AddEditComplaint", mode: "add" }, function () {
                        $('#ComplaintText').jqxEditor({
                            height: '200px',
                            width: '800px'
            $('#AddNewWindow').jqxWindow('open');
    And this is the HTML:
    <div id=”AddNewWindow”> @*popup window for adding new complaints*@
    <div id=”title”>complaint </div>
    <div>
    <div id=”tabs”>
    • Main
    • Actions
    • Parts
    • Attachments
    <div id=”AddnewDiv”></div>
    <div> action tab </div>
    <div> parts tab </div>
    <div>attachments tab</div>
    </div>`
    So the content of the tab itself is static but the content of the first tab is dynamically loaded with the load function. (it loads a partial view with an form)
    It works fine but the strange thing is that when the content of the first (AddnewDiv) tab shows an I click again on that tab, the content is hiding.
    clicking the again an the content shows again. and so on! I can not explain why.
    jqxtab inside jqxwindow behaving strange #98683
    Hi RobWarning,
    I would like to suggest you to implement also the initTabContent in order to initialize the content inside the tabs.
    https://www.jqwidgets.com
    jqxtab inside jqxwindow behaving strange #98699
    RobWarning
    This is indeed solving the problem! thank you Peter.
