jQuery UI Widgets Forums Scheduler JqxScheduler timezone issue.
This topic contains 5 replies, has 3 voices, and was last updated by  admin 5 years, 2 months ago.
  • JqxScheduler timezone issue. #108373
    We’re using jqwidgets-ver8.3.2 at the moment.
    We are facing issue in displaying appointments when local timezone and scheduler timezone is different.
    Our local timezone is “Indian Standard Time(IST)” and scheduler timezone is “Eastern Standard time(EST)”.
    We have added appointment on 13th March 2020 from 5:00 p.m to 6:00 pm (IST) as shown in the below pic.
    https://simplemobeecms.blob.core.windows.net/general/timezone_1.png
    It is displaying in correct time in the scheduler but when we open the appointment time shown is 1 hour earlier than the added time.
    https://simplemobeecms.blob.core.windows.net/general/timezone_2.png
    We have added another appointment on 13th March 2020 from 6:00 pm to 6: 30 pm (IST) as shown in the below pic.
    https://simplemobeecms.blob.core.windows.net/general/timezone_4.png
    The second appointment is displaying half an hour earlier then the expected time.
    https://simplemobeecms.blob.core.windows.net/general/timezone_3.png
    We are maintaining requested appointment in sql server database table.
    In our database table appointment requested time is stored in UTC format correctly.
    JqxScheduler timezone issue. #108377
    Please, share jsfiddle.net or codepen.io example which demonstrates the reported behavior. This will help us to debug by using the same settings which you use.
    Peter
    JqxScheduler timezone issue. #109674
    Hello Peter Stoev,
    You can check and debug the issue with the following link,
    https://jseditor.io/?key=jqxscheduler-appointmentdatafields-property
    JqxScheduler timezone issue. #110106
    admin
    I think the link is incorrect. You posted one of our demos.
    Peter
    JqxScheduler timezone issue. #111428
    Link is correct only, scheduler behaves same as it behave in my demo.
    Thanks.
    JqxScheduler timezone issue. #111429
    admin
    We will continue testing the behavior. For now, we cannot reproduce it. Probably, because we are in different time zones.
    Peter
