jQuery UI Widgets › Forums › Plugins › AngularJS › jqxmenu with Angular and ui.router – issue with clickhandler
This topic contains 4 replies, has 2 voices, and was last updated by Peter Stoev 9 years, 2 months ago.
jQWidgets Ver 4.0.
Jqxmenu clickHandler function is not working with ‘sref’. ui.router feature works but doesn’t change state upon menu click.
here is my code.
Thnaks,
Keshavan<!DOCTYPE html> <html ng-app="demoApp" lang="en"> <head> <title id='Description'>The demo demonstrates the Minimized state of jqxMenu.</title> <link rel="stylesheet" type="text/css" href="/angularjs/jQWidgets/jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/jquery-1.11.1.min.js"></script> <script src="//ajax.googleapis.com/ajax/libs/angularjs/1.3.15/angular.min.js"></script> <script src="//angular-ui.github.io/ui-router/release/angular-ui-router.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/demos.js"></script> <script src="https://cdn.firebase.com/js/client/2.2.4/firebase.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/globalization/globalize.js"></script> <script src="https://cdn.firebase.com/libs/angularfire/1.1.3/angularfire.min.js"></script> <script type="text/javascript"> var demoApp = angular.module("demoApp", ["ui.router", "jqwidgets"]); demoApp.config(function ($stateProvider, $urlRouterProvider) { // For any unmatched url, send to /route1 $urlRouterProvider.otherwise("Quotations") $stateProvider .state('Quotations', { templateUrl: "/body.html", controller: 'demoController', controllerAs: 'test' }) .state('Messages', { templateUrl: "/body2.html", controller: 'demoController', controllerAs: 'test' }) }) demoApp.controller('MainCtrl', function ($state) { $state.transitionTo('Quotations'); }) demoApp.controller('demoController', function ($state, $scope) { var test = this; test.templateUrl = '/body2.html'; $scope.checked = true; var menu = {}; $scope.clickHandler = function (event) { var args = event.args; $scope.log = "Clicked: " + $(args).text(); }; $scope.log = ""; $scope.menuSettings = { width: '100%', height: '32px', created: function (args) { menu = args.instance; menu.minimize(); } }; $scope.changeState = function () { if ($scope.checked) { menu.minimize(); } else { menu.restore(); } } }); </script> </head>
Please find the updated code.
jQWidgets Ver 4.0.
here is my code.Thanks,
<html ng-app=”demoApp” lang=”en”><head> <title id='Description'>The demo demonstrates the Minimized state of jqxMenu.</title> <link rel="stylesheet" type="text/css" href="/angularjs/jQWidgets/jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/jquery-1.11.1.min.js"></script> <script src="//ajax.googleapis.com/ajax/libs/angularjs/1.3.15/angular.min.js"></script> <script src="//angular-ui.github.io/ui-router/release/angular-ui-router.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/demos.js"></script> <script src="https://cdn.firebase.com/js/client/2.2.4/firebase.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/globalization/globalize.js"></script> <script src="https://cdn.firebase.com/libs/angularfire/1.1.3/angularfire.min.js"></script> <script type="text/javascript"> var demoApp = angular.module("demoApp", ["ui.router", "jqwidgets"]); demoApp.config(function ($stateProvider, $urlRouterProvider) { // For any unmatched url, send to /route1 $urlRouterProvider.otherwise("Quotations") $stateProvider .state('Quotations', { templateUrl: "/body.html", controller: 'demoController', controllerAs: 'test' }) .state('Messages', { templateUrl: "/body2.html", controller: 'demoController', controllerAs: 'test' }) }) demoApp.controller('MainCtrl', function ($state) { $state.transitionTo('Quotations'); }) demoApp.controller('demoController', function ($state, $scope) { var test = this; test.Url = "/"; test.templateUrl = "/body.html"; $scope.checked = true; var menu = {}; $scope.menuSettings = { width: '100%', height: '32px', created: function (args) { menu = args.instance; menu.minimize(); } }; $scope.changeState = function () { if ($scope.checked) { menu.minimize(); } else { menu.restore(); } } }); </script> </head> <body ng-controller="MainCtrl"> <jqx-menu jqx-settings="menuSettings" > <ul> <li><a sref="Quotations">Quotations</a></li> <li><a sref="Messages">Messages</a></li> <li><a sref="Logout">Logout</a></li> </ul> </jqx-menu> <jqx-check-box ng-model="checked " ng-change="changeState($event) ">Minimized</jqx-check-box> <br/> <div ui-view></div> </body> </html>
Hi Keshavan,
I don’t see a reason the clickhandler to be called. No binding to events.
Doesn’t work even after binding to events.
Here is my updated code, Please help.
Keshavan<!DOCTYPE html> <html ng-app="demoApp" lang="en"> <head> <title id='Description'>The demo demonstrates the Minimized state of jqxMenu.</title> <link rel="stylesheet" type="text/css" href="/angularjs/jQWidgets/jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/jquery-1.11.1.min.js"></script> <script src="//ajax.googleapis.com/ajax/libs/angularjs/1.3.15/angular.min.js"></script> <script src="//angular-ui.github.io/ui-router/release/angular-ui-router.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/demos.js"></script> <script src="https://cdn.firebase.com/js/client/2.2.4/firebase.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/globalization/globalize.js"></script> <script src="https://cdn.firebase.com/libs/angularfire/1.1.3/angularfire.min.js"></script> </head> <body ng-controller="MainCtrl"> <script type="text/javascript"> var demoApp = angular.module("demoApp", ["ui.router", "jqwidgets"]); demoApp.config(function ($stateProvider, $urlRouterProvider) { // For any unmatched url, send to /route1 $urlRouterProvider.otherwise("Quotations") $stateProvider .state('Quotations', { templateUrl: "/body.html", controller: 'demoController', controllerAs: 'test' }) .state('Messages', { templateUrl: "/body2.html", controller: 'demoController', controllerAs: 'test' }) }) demoApp.controller('MainCtrl', function ($state) { $state.transitionTo('Quotations'); }) demoApp.controller('demoController', function ($state, $scope) { var test = this; test.Url = "/"; test.templateUrl = "/body.html"; $scope.checked = true; var menu = {}; $scope.menuSettings = { width: '100%', height: '32px', created: function (args) { menu = args.instance; menu.minimize(); } }; $scope.changeState = function () { if ($scope.checked) { menu.minimize(); } else { menu.restore(); } } $scope.clickHandler = function (event) { var args = event.args; $scope.log = "Clicked: " + $(args).text(); }; $scope.log = ""; }); </script> <jqx-menu jqx-on-itemclick="clickHandler($event)" jqx-settings="menuSettings"> <ul> <li><a sref="Quotations">Quotations</a></li> <li><a sref="Messages">Messages</a></li> <li><a sref="Logout">Logout</a></li> </ul> </jqx-menu> <jqx-check-box ng-model="checked " ng-change="changeState($event) ">Minimized</jqx-check-box> <br/> <div style='margin-left: 20px; float: left;'> {{log}} </div> <div ui-view></div> </body> </html>
Hi Keshavan,
Example with 2 widgets – jqxMenu and jqxDropDownList. Both widgets are bound to events. The example is tested with jQWidgets 4.0.0 and works as expected.
contacts.html
<div> <jqx-drop-down-list jqx-on-change="change(event)" jqx-settings="dropDwn.dropDownListSettings"></jqx-drop-down-list> <jqx-menu jqx-on-itemclick="itemclick(event)" jqx-settings="dropDwn.menuSettings"> <ul> <li> Item 1 <ul> <li>Sub Item 1</li> <li>Sub Item 2</li> <li>Sub Item 3</li> </ul> </li> <li> Item 2 </li> <li> Item 3 </li> </ul> </jqx-menu> </div>
dropdownlist-angular-ui-router.htm
<!DOCTYPE html> <html ng-app="myapp"> <head> <title id="Description">jqxDropDownList directive for Angular UI Router</title> <link rel="stylesheet" type="text/css" href="../../jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script src="//ajax.googleapis.com/ajax/libs/angularjs/1.3.15/angular.min.js"></script> <script src="//angular-ui.github.io/ui-router/release/angular-ui-router.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> </head> <body ng-controller="MainCtrl" class="container"> <div ui-view></div> <!-- App Script --> <script> var myapp = angular.module('myapp', ["ui.router", "jqwidgets"]) myapp.config(function ($stateProvider, $urlRouterProvider) { // For any unmatched url, send to /route1 $urlRouterProvider.otherwise("/route1") $stateProvider .state('contacts', { templateUrl: 'contacts.html', controller: 'ContactCtrl', controllerAs: 'dropDwn' }) }); myapp.controller('MainCtrl', function ($state) { $state.transitionTo('contacts'); }) myapp.controller('ContactCtrl', function ($state, $scope) { var dropDwn = this; dropDwn.people = [{ id: 1, name: "Pedro", age: 13 }, { id: 2, name: "Clara", age: 22 }, { id: 3, name: "John", age: 33 }, { id: 4, name: "Pier", age: 27 }]; // init DropDownList's settings object. dropDwn.dropDownListSettings = { width: 200, height: 30, autoDropDownHeight: true, displayMember: "name", valueMember: "id", source: dropDwn.people } $scope.change = function (event) { var args = event.args; }; dropDwn.menuSettings = { width: 300, height:30 } $scope.itemclick = function (event) { alert("Item clicked"); } }) </script> </body> </html>
