jQuery UI Widgets Forums Grid jqxMenu – problem when 'minimize'd
This topic contains 4 replies, has 2 voices, and was last updated by  Peter Stoev 10 years, 10 months ago.
  • jqxMenu – problem when 'minimize'd #58633
    Adarsha
    I am using below code to get the ‘minimize’menu. Also, here i’m trying to get the menu in horizontal when i click ‘minimize’ icon. I can see the UL lists, but the LI under UL are not displayed. Autoopen on UL works fine but the opned LI elements are not visible. I can see a line dropping down. Looks like only left-borders of LI elemets.
    Can anyone help here please !
    $(“#menubar”).jqxMenu({
    theme:’arctic’
    $(“#menubar”).jqxMenu(‘minimize’);
    autoCloseOnMouseLeave: true,
    mode: “horizontal”
    jqxMenu – problem when 'minimize'd #58634
    Adarsha
    Also i have to click the minimize button to open the menu. Any when to make it auto open?
    jqxMenu – problem when 'minimize'd #58639
    Hi adarsha,
    1. You cannot minimize a menu in the Grid.
    2. Please, look at the Menu’s sample where it is demonstrated how you should minimize the Menu.
    jqxMenu – problem when 'minimize'd #58666
    Adarsha
    Thanks Peter,
    Also, it would be interesting to know, is there any way that i can display the minimize’d menu horizontally. should below code work?
    theme:’fresh’,
    width: ‘100%’,
    height: ’32px’,
    autoSizeMainItems: true,
    mode: “horizontal”
    $(“#jqxMenu”).css(‘visibility’, ‘visible’);
    jqxMenu – problem when 'minimize'd #58675
    Hi adarsha,
    The representation is only vertical. Please, also post your jqxMenu questions in the jqxMenu’s Forum, not in jqxGrid’s.
