jQuery UI Widgets Forums General Discussions jqxLoader problem
This topic contains 1 reply, has 2 voices, and was last updated by  svetoslav_borislavov 2 years, 2 months ago.
  • jqxLoader problem #132727
    masda
    good afternoon,
    with the following code the loader never appears
    $(‘#btSave’).click(function(){
    $(‘#body’).jqxValidator(‘validate’);
    $(‘#body’).on(‘validationSuccess’, function () {
    $(‘#jqxLoader’).jqxLoader(‘open’);
    var aFormData = new FormData();
    but if I make this:
    It works.
    what is the problem?
    jqxLoader problem #132729
    Did you initialize the jqxValidator, because you are trying to use an Event from the jqxVaildator?
    This event will never be raised and the code in it will never be executed if you don’t have jqxValidator.
    Also, a demo will be helpful!
    Svetoslav Borislavov
    https://www.jqwidgets.com/
