jQuery UI Widgets Forums Getting Started JQXLite is not a function (using react)
This topic contains 2 replies, has 2 voices, and was last updated by  cyclim 8 years ago.
  • cyclim
    Hi, I am trying out jqwidgets using react. Encounter TypeError: JQXLite is not a function
    Please assist, thanks. Below how i the error is generated:
    1) created react project using create-react-app
    2) created html:
    <!doctype html>
    <html lang=”en”>
    <meta charset=”utf-8″>
    <link rel=”manifest” href=”%PUBLIC_URL%/manifest.json”>
    <link rel=”shortcut icon” href=”%PUBLIC_URL%/favicon.ico”>
    <link rel=”stylesheet” href=”../../jqwidgets/styles/jqx.darkblue.css” type=”text/css” />
    <script type=”text/javascript” src=”../src/jqwidgets/scripts/jquery-1.11.1.min.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqwidgets/jqxwindow.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxmenu.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxgrid.js”></script>
    <script type=”text/javascript” src=”../src/jqwidgets/jqwidgets/jqxgrid.selection.js”></script>
    <title>React App</title>
    <body>
    <div id=”root”></div>
    3) index.js
    ReactDOM.render(<App />, document.getElementById(‘root’));
    4) App.js
    import React, { Component } from ‘react’;
    import JqxBarGauge from ‘./jqwidgets/jqwidgets-react/react_jqxbargauge.js’;
    class App extends Component {
    render() {
    return (
    <JqxBarGauge
    width={600} height={600} max={150}
    colorScheme={‘scheme02’} values={[102, 115, 130, 137]}
    export default App;
    5) ran: npm install jqwidgets-framework
    6) Have copied the following jqwidgets folders (taken from node_modules) to /src/jqwidgets directory:
    /jqwidgets
    /jqwidgets-rect
    /scripts
    /styles
    7) ran: npm start, browser throw the following error:
    JqxBarGauge.createComponent
    C:\project\sms\try_apps\jqw03\src\jqwidgets\jqwidgets-react\react_jqxbargauge.js:44
    41 | }
    42 | }
    43 | if(!this.template) {
    > 44 | JQXLite(this.componentSelector).html(this.props.template);
    45 | }
    46 | JQXLite(this.componentSelector).jqxBarGauge(options);
    47 | };
    View compiled
    JqxBarGauge.componentDidMount
    C:\project\sms\try_apps\jqw03\src\jqwidgets\jqwidgets-react\react_jqxbargauge.js:13
    10 | export default class JqxBarGauge extends React.Component {
    11 | componentDidMount() {
    12 | let options = this.manageAttributes();
    > 13 | this.createComponent(options);
    14 | };
    15 | manageAttributes() {
    16 | let properties = [‘animationDuration’,’backgroundColor’,’barSpacing’,’baseValue’,’colorScheme’,’customColorScheme’,’disabled’,’endAngle’,’formatFunction’,’height’,’labels’,’max’,’min’,’relativeInnerRadius’,’rendered’,’startAngle’,’title’,’tooltip’,’useGradient’,’values’,’width’];
    View compiled
    (anonymous function)
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactCompositeComponent.js:265
    262 | if (process.env.NODE_ENV !== ‘production’) {
    263 | transaction.getReactMountReady().enqueue(function () {
    264 | measureLifeCyclePerf(function () {
    > 265 | return inst.componentDidMount();
    266 | }, _this._debugID, ‘componentDidMount’);
    267 | });
    268 | } else {
    View compiled
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactCompositeComponent.js:75
    72 |
    73 | ReactInstrumentation.debugTool.onBeginLifeCycleTimer(debugID, timerType);
    74 | try {
    > 75 | return fn();
    76 | } finally {
    77 | ReactInstrumentation.debugTool.onEndLifeCycleTimer(debugID, timerType);
    78 | }
    View compiled
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactCompositeComponent.js:264
    261 | if (inst.componentDidMount) {
    267 | });
    View compiled
    CallbackQueue.notifyAll
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\CallbackQueue.js:76
    73 | this._callbacks = null;
    74 | this._contexts = null;
    75 | for (var i = 0; i < callbacks.length; i++) {
    > 76 | callbacks[i].call(contexts[i], arg);
    77 | }
    78 | callbacks.length = 0;
    79 | contexts.length = 0;
    View compiled
    ReactReconcileTransaction.close
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactReconcileTransaction.js:80
    77 | * After DOM is flushed, invoke all registered onDOMReady callbacks.
    78 | */
    79 | close: function () {
    > 80 | this.reactMountReady.notifyAll();
    81 | }
    82 | };
    83 |
    View compiled
    ReactReconcileTransaction.closeAll
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\Transaction.js:206
    203 | // wrapper.close threw.
    204 | errorThrown = true;
    205 | if (initData !== OBSERVED_ERROR && wrapper.close) {
    > 206 | wrapper.close.call(this, initData);
    207 | }
    208 | errorThrown = false;
    209 | } finally {
    View compiled
    ReactReconcileTransaction.perform
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\Transaction.js:153
    150 | } else {
    151 | // Since method didn’t throw, we don’t want to silence the exception
    152 | // here.
    > 153 | this.closeAll(0);
    154 | }
    155 | } finally {
    156 | this._isInTransaction = false;
    View compiled
    batchedMountComponentIntoNode
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactMount.js:126
    123 | var transaction = ReactUpdates.ReactReconcileTransaction.getPooled(
    124 | /* useCreateElement */
    125 | !shouldReuseMarkup && ReactDOMFeatureFlags.useCreateElement);
    > 126 | transaction.perform(mountComponentIntoNode, null, componentInstance, container, transaction, shouldReuseMarkup, context);
    127 | ReactUpdates.ReactReconcileTransaction.release(transaction);
    128 | }
    129 |
    View compiled
    ReactDefaultBatchingStrategyTransaction.perform
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\Transaction.js:140
    137 | // one of these calls threw.
    138 | errorThrown = true;
    139 | this.initializeAll(0);
    > 140 | ret = method.call(scope, a, b, c, d, e, f);
    141 | errorThrown = false;
    142 | } finally {
    143 | try {
    View compiled
    Object.batchedUpdates
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactDefaultBatchingStrategy.js:62
    59 | if (alreadyBatchingUpdates) {
    60 | return callback(a, b, c, d, e);
    61 | } else {
    > 62 | return transaction.perform(callback, null, a, b, c, d, e);
    63 | }
    64 | }
    65 | };
    View compiled
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactUpdates.js:97
    94 |
    95 | function batchedUpdates(callback, a, b, c, d, e) {
    96 | ensureInjected();
    > 97 | return batchingStrategy.batchedUpdates(callback, a, b, c, d, e);
    98 | }
    99 |
    100 | /**
    View compiled
    Object._renderNewRootComponent
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactMount.js:320
    317 | // rendering, in componentWillMount or componentDidMount, will be batched
    318 | // according to the current batching strategy.
    319 |
    > 320 | ReactUpdates.batchedUpdates(batchedMountComponentIntoNode, componentInstance, container, shouldReuseMarkup, context);
    321 |
    322 | var wrapperID = componentInstance._instance.rootID;
    323 | instancesByReactRootID[wrapperID] = componentInstance;
    View compiled
    Object._renderSubtreeIntoContainer
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactMount.js:401
    398 | }
    399 |
    400 | var shouldReuseMarkup = containerHasReactMarkup && !prevComponent && !containerHasNonRootReactChild;
    > 401 | var component = ReactMount._renderNewRootComponent(nextWrappedElement, container, shouldReuseMarkup, nextContext)._renderedComponent.getPublicInstance();
    402 | if (callback) {
    403 | callback.call(component);
    404 | }
    View compiled
    Object.render
    C:\project\sms\try_apps\jqw03\node_modules\react-dom\lib\ReactMount.js:422
    419 | * @return {ReactComponent} Component instance rendered in container.
    420 | */
    421 | render: function (nextElement, container, callback) {
    > 422 | return ReactMount._renderSubtreeIntoContainer(null, nextElement, container, callback);
    423 | },
    424 |
    425 | /**
    View compiled
    C:\project\sms\try_apps\jqw03\src\index.js:7
    4 | import registerServiceWorker from ‘./registerServiceWorker’;
    5 | import ‘./index.css’;
    6 |
    > 7 | ReactDOM.render(<App />, document.getElementById(‘root’));
    8 | registerServiceWorker();
    9 |
    10 |
    View compiled
    ▶ 6 stack frames were collapsed.
    You are missing to include required scripts such as jqxcore.js or you are using old scripts or the URLs are incorrect. All our demos use JQXLite. For using create-react-app, follow strictly the instructions documented on: http://www.jqwidgets.com/reactjs-components-documentation/documentation/create-react-app
    Hope this helps.
    cyclim
    Thank you! I followed the instructions and it works fine now.
