jQuery UI Widgets Forums General Discussions jqxInput problem in 2.7
This topic contains 5 replies, has 3 voices, and was last updated by  wavetrex 12 years, 4 months ago.
  • jqxInput problem in 2.7 #16795
    Tony C
    I have the following auto-complete which works perfectly in 2.61.
    I updated to 2.7 and now there are no suggestions appearing under the input field. There are no errors logged in the console & I can see in firebug that the suggestions are being returned correctly from the web service. I reverted to 2.61 and the suggestions appear again.
    Has something changed between 2.61 and 2.7 that I am missing, or is my definition bad/incomplete ?
    thanks & regards
    Tony C
    	$("#xtrdist").jqxInput({
    placeHolder : "cust name or number",
    height : 25,
    width : 300,
    theme : theme,
    source : function(query, response) {
    var dataAdapter = new $.jqx.dataAdapter({
    datatype : "json",
    datafields : [{
    type : 'string'
    type : 'string'
    url : '/wiaweb/custsuggj.pgm',
    data : {
    query : "none"
    autoBind : true,
    formatData : function(data) {
    data.query = query;
    return data;
    loadComplete : function(data) {
    //console.log(data);
    if (data.records.length > 0) {
    response($.map(data.records, function(item) {
    return {
    label : item.name
    jqxInput problem in 2.7 #16804
    Hi Tony C,
    The only change in jqxInput is that in jQWidgets 2.7, the popup is positioned below the input with absolute position. If you have content with higher z-index than the input, it could be displayed behind it.
    jqxInput problem in 2.7 #16886
    wavetrex
    Yeh, I encountered the same issue and reported it a little while back.
    There is a temporary workaround for it until it will be solved, add this to your styles:
    .jqx-menu {
    z-index: 100000;
    jqxInput problem in 2.7 #16892
    Tony C
    Thanks wavetrex, that kludge solved the problem 🙂
    below is my cut down code that demonstrates of the problem. The window (myWin) is created with a z-index of 9001, once typing into the field (myField) commences, the suggestions are created in the DOM at the correct absolute position, but with no z-index (i.e. auto), therefore they are unseen.
    <html>
    <script type="text/javascript" src="../../jqwidgets/jqxinput.js"></script>
    <body>
    var countries = new Array("Afghanistan", "Albania", "Algeria", "Andorra", "Angola", "Antarctica", "Antigua and Barbuda", "Argentina", "Armenia", "Australia", "Austria", "Azerbaijan", "Bahamas", "Bahrain", "Bangladesh", "Barbados", "Belarus", "Belgium", "Belize", "Benin", "Bermuda", "Bhutan", "Bolivia", "Bosnia and Herzegovina", "Botswana", "Brazil", "Brunei", "Bulgaria", "Burkina Faso", "Burma", "Burundi", "Cambodia", "Cameroon", "Canada", "Cape Verde", "Central African Republic", "Chad", "Chile", "China", "Colombia", "Comoros", "Congo, Democratic Republic", "Congo, Republic of the", "Costa Rica", "Cote d'Ivoire", "Croatia", "Cuba", "Cyprus", "Czech Republic", "Denmark", "Djibouti", "Dominica", "Dominican Republic", "East Timor", "Ecuador", "Egypt", "El Salvador", "Equatorial Guinea", "Eritrea", "Estonia", "Ethiopia", "Fiji", "Finland", "France", "Gabon", "Gambia", "Georgia", "Germany", "Ghana", "Greece", "Greenland", "Grenada", "Guatemala", "Guinea", "Guinea-Bissau", "Guyana", "Haiti", "Honduras", "Hong Kong", "Hungary", "Iceland", "India", "Indonesia", "Iran", "Iraq", "Ireland", "Israel", "Italy", "Jamaica", "Japan", "Jordan", "Kazakhstan", "Kenya", "Kiribati", "Korea, North", "Korea, South", "Kuwait", "Kyrgyzstan", "Laos", "Latvia", "Lebanon", "Lesotho", "Liberia", "Libya", "Liechtenstein", "Lithuania", "Luxembourg", "Macedonia", "Madagascar", "Malawi", "Malaysia", "Maldives", "Mali", "Malta", "Marshall Islands", "Mauritania", "Mauritius", "Mexico", "Micronesia", "Moldova", "Mongolia", "Morocco", "Monaco", "Mozambique", "Namibia", "Nauru", "Nepal", "Netherlands", "New Zealand", "Nicaragua", "Niger", "Nigeria", "Norway", "Oman", "Pakistan", "Panama", "Papua New Guinea", "Paraguay", "Peru", "Philippines", "Poland", "Portugal", "Qatar", "Romania", "Russia", "Rwanda", "Samoa", "San Marino", " Sao Tome", "Saudi Arabia", "Senegal", "Serbia and Montenegro", "Seychelles", "Sierra Leone", "Singapore", "Slovakia", "Slovenia", "Solomon Islands", "Somalia", "South Africa", "Spain", "Sri Lanka", "Sudan", "Suriname", "Swaziland", "Sweden", "Switzerland", "Syria", "Taiwan", "Tajikistan", "Tanzania", "Thailand", "Togo", "Tonga", "Trinidad and Tobago", "Tunisia", "Turkey", "Turkmenistan", "Uganda", "Ukraine", "United Arab Emirates", "United Kingdom", "United States", "Uruguay", "Uzbekistan", "Vanuatu", "Venezuela", "Vietnam", "Yemen", "Zambia", "Zimbabwe");
    $("#myWin").jqxWindow({
    width : 450,
    height : 300,
    resizable : false,
    autoOpen : false
    $("#myField").jqxInput({
    placeHolder : "enter country",
    height : 25,
    width : 250,
    source : countries
    $("#myWin").jqxWindow('show');
    <div id="myWin">
    <div>
    Pick a Country Window
    <div>
    Country
    <input id="myField" />
    jqxInput problem in 2.7 #17816
    Tony C
    fixed in 2.8 release, thanks 🙂
    jqxInput problem in 2.7 #17979
    wavetrex
    Confirmed, it has been solved in 2.8
    Now the Z-Index for the menu is set automatically ( in my case it’s 20000 ).
    Can be closed, thanks !
