jQuery UI Widgets Forums General Discussions jqxInput Autocomplete issue
This topic contains 2 replies, has 2 voices, and was last updated by  vagkom 12 years, 4 months ago.
  • jqxInput Autocomplete issue #16589
    vagkom
    Hello guys,
    And once again great job!
    I have an autocomplete input field which is in the upper 20% area of a horizontally splitted screen.
    So when the pop up fires up, I lose a few rows results because it is covered by the rest half of the sreen. So either I must control the length of the popup and use scroll bars to navigate, or alternatively the popup could show above the second half (80%) of the screen and not under it.
    I understand that each splitted part is completely separate but I am trying to solve my problem as well.
    Is there any workaround ?
    Best Regards
    Vangelis
    jqxInput Autocomplete issue #16593
    Hi Vangelis,
    The popup’s height can be controlled by setting the “items” property of the jqxInput to a number. By default it can display up to 8 items. It is not possible to change the display position of the popup.
    jqxInput Autocomplete issue #16596
    vagkom
    Thanks a lot for your reply. I am aware of the items property but the problem is I am using it with google maps and when I define 3 (for example) then the addresses returned are minimized to 3. Anyway I can change the design it is better.
    Best Regards
    Vangelis Komninos
