jQuery UI Widgets › Forums › Grid › jqxGrid('focus') does not work in Chrome
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 11 years, 5 months ago.
I need to select one cell of the grid when page is loaded.
I use the code(function ($) { var dataUrl = '@Url.Action("GetCityData")'; var gridSelector = "#cityGrid"; $(document).ready(function () { var source = { datatype: 'json', dataFields: [ { name: 'id', type: 'Number' }, { name: 'name', type: 'String' }, { name: 'population', type: 'Number'}, { name: 'year', type: 'Number' }, { name: 'country', type: 'String' } ], url: dataUrl, id: 'id' }; var dataAdapter = new $.jqx.dataAdapter(source); $(gridSelector).jqxGrid({ source: dataAdapter, selectionmode: 'singlecell', theme: 'classic', columns: [ { text: 'Name', dataField: 'name', width: 150 }, { text: 'Foundation Year', dataField: 'year', width: 150 }, { text: 'Population', dataField: 'population', width: 200 }, { text: 'Country', dataField: 'country' } ] }); setTimeout(function () { $(gridSelector).jqxGrid('selectcell', 0, 'name'); $(gridSelector).jqxGrid('focus'); }, 5); }); })(jQuery);
But it works well only in Internet Explorer. In Chrome the cell is selected, but grid has no focus and keyboard navigation does not work. What should I do to deal with this problem?
Hi alex_svs_fl,
You do it incorrectly. ‘selectcell’ and ‘focus’ should be called within the Grid’s ready callback or within the Grid’s bindingcomplete event handler. Otherwise, you will try to focus element which is not created.
http://www.jqwidgets.comPeter, thanks for answer. I have changed my code and placed the code $(gridSelector).jqxGrid(‘selectcell’, 0, ‘name’);
$(gridSelector).jqxGrid(‘focus’); to ready() function in the grid initialization. But nothing has been changed, Chrome continues to work without focus on the required cell.Hi alex_svs_fl,
You are right. I am sorry for my previous response. It seems that I missed that. I will create a work item for the reported issue. The focus seems to be put only after you Click within the Grid, but the method does not work correctly in Chrome for some reason. We will do our best to fix that.
