jQuery UI Widgets Forums Grid JqxGrid Scrollbar Problem
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 12 years, 9 months ago.
  • JqxGrid Scrollbar Problem #9250
    sreeni379
    HI,
    I  have problem in scrolling  in grid , when i click horizontal scroll bar it is  saying “Object Error”, following code i have written for grid ,please help me .
                                 { name: 'InSelect', type: 'boolean' },
                                 { name: 'UserID' },
                                 { name: 'UserName' },
                                 { name: 'UserEmail' },
                                 { name: 'Status' },
                                 { name: 'SuperAdmin', type: 'boolean' },
                                 { name: 'LOBAdmin', type: 'boolean' },
                                 { name: 'DataAdmin', type: 'boolean' },
                                 { name: 'SecurityAdmin', type: 'boolean' },
                                 { name: 'Publisher' }
                         data: ArrayVal,
                         url: '../UserAdmin/GridInternaluserAdmin/'
                    var columnCheckBox = null;
                    var updatingCheckState = false;
                    // initialize jqxGrid. Disable the built-in selection.
                    $("#Injqxgrid").jqxGrid(
                        width: 886,
                        height: 206,
                        enablehover: false,
                        selectionmode: 'none',
                              text: '', datafield: 'InSelect', columntype: 'checkbox',sortable: false , width: 40,
                              renderer: function () {
                                  return '<div style="margin-left: 10px; margin-top: 5px;"></div>';
                              rendered: function (element) {
                                  $(element).jqxCheckBox({ theme: theme, width: 16, height: 16, animationShowDelay: 0, animationHideDelay: 0, hasThreeStates: false });
                                  columnCheckBox = $(element);
                                  var rowscount = $("#Injqxgrid").jqxGrid('getrows').length;
                                  $(element).bind('change', function (event) {
                                      var IndexesArray = new Array();
                                          var visibleIndex = $("#Injqxgrid").jqxGrid('getrowvisibleindex', i);
                                          IndexesArray.push({ bound: i, visible: visibleIndex });
                                      var paginginformation = $("#Injqxgrid").jqxGrid('getpaginginformation');
                                      var pagenum = paginginformation.pagenum;
                                      var pagesize = paginginformation.pagesize;
                                      var pageArray = new Array();
                                      for (var j = 0; j < rowscount; j++) {
                                          if (IndexesArray[j].visible >= pagenum * pagesize && IndexesArray[j].visible < (pagenum + 1) * pagesize) {
                                              pageArray.push(IndexesArray[j].bound);
                                              $("#Injqxgrid").jqxGrid('setcellvalue', IndexesArray[j].bound, 'InSelect', event.args.checked);
                                      var checked = event.args.checked;
                                      if (checked == null || updatingCheckState) return;
                                      $("#Injqxgrid").jqxGrid('beginupdate');
                                      if (checked == true) {
                                          $("#Injqxgrid").jqxGrid({ selectedrowindexes: pageArray });
                                      } else if (checked == false) {
                                          $("#Injqxgrid").jqxGrid('clearselection');
                                      $("#Injqxgrid").jqxGrid('endupdate');
                                  $("#Injqxgrid").bind("pagechanged", function (event) {
                                      var args = event.args;
                                      var pagenum = args.pagenum;
                                      var pagesize = args.pagesize;
                                      var selectedNumber = 0;
                                      for (var k = 0; k < rowscount; k++) {
                                          if (IndexesArray[k].visible >= pagenum * pagesize && IndexesArray[k].visible < (pagenum + 1) * pagesize) {
                                              var value = $("#Injqxgrid").jqxGrid('getcellvalue', IndexesArray[k].bound, 'InSelect');
                                              if (value == true) {
                                                  $("#Injqxgrid").jqxGrid('selectrow', IndexesArray[k].bound);
                                                  selectedNumber += 1;
                                              } else {
                                                  $('#Injqxgrid').jqxGrid('unselectrow', IndexesArray[k].bound);
                                      if (selectedNumber == pagesize) {
                                          $(element).jqxCheckBox('check');
                                      } else if (selectedNumber == 0) {
                                          $(element).jqxCheckBox('uncheck');
                                    { text: 'UserID ', dataField: 'UserID', editable: false, width: 90 },
                                    { text: 'UserName ', dataField: 'UserName', editable: false, width: 100 },
                                    { text: 'UserEmail ', dataField: 'UserEmail', editable: false, width: 120 },
                                    { text: 'Status', dataField: 'Status', editable: false, width: 90 },
                                    { text: 'SuperAdmin', dataField: 'SuperAdmin', columntype: 'checkbox',sortable: false , width: 100 },
                                    { text: 'LOBAdmin', dataField: 'LOBAdmin', columntype: 'checkbox',sortable: false , width: 90 },
                                    { text: 'DataAdmin', dataField: 'DataAdmin', columntype: 'checkbox',sortable: false , width: 90 },
                                    { text: 'SecurityAdmin ', dataField: 'SecurityAdmin', columntype: 'checkbox',sortable: false , width: 100 },
                                    { text: 'Publisher', dataField: 'Publisher', editable: false,sortable: false , width: 90 }
    JqxGrid Scrollbar Problem #9320
    Hello sreeni379,
    Using your code snippet, we created an example but could not reproduce the reported issue. Here is the example:
    <title></title>
    <link rel="stylesheet" href="../../jqwidgets2.4.2/jqwidgets/styles/jqx.base.css"
    type="text/css" />
    <script type="text/javascript" src="../../scripts/jquery-1.8.1.min.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.edit.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxcheckbox.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.pager.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.sort.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxlistbox.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxdropdownlist.js"></script>
    var theme = 'classic';
    { name: 'UserID' },
    { name: 'Status' },
    // data: ArrayVal,
    url: "Admin.txt"
    width: 886,
    height: 206,
    enablehover: false,
    text: '', datafield: 'InSelect', columntype: 'checkbox', sortable: false, width: 40,
    } else {
    { text: 'SuperAdmin', dataField: 'SuperAdmin', columntype: 'checkbox', sortable: false, width: 100 },
    { text: 'LOBAdmin', dataField: 'LOBAdmin', columntype: 'checkbox', sortable: false, width: 90 },
    { text: 'DataAdmin', dataField: 'DataAdmin', columntype: 'checkbox', sortable: false, width: 90 },
    { text: 'SecurityAdmin ', dataField: 'SecurityAdmin', columntype: 'checkbox', sortable: false, width: 100 },
    { text: 'Publisher', dataField: 'Publisher', editable: false, sortable: false, width: 90 }
    <body>
    <div id="Injqxgrid">
    At our side there is no issue with the scrollbar. if it persists at your side, could you please share more feedback, such as your browser and its version and the version of jQWidgets you use.
