jQuery UI Widgets › Forums › Grid › jqxgrid row edit problem
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 11 years, 5 months ago.
Authorjqxgrid row edit problem Posts
I have a grid with some data and I have a contextmenu for editing the selected row data. when I select a row and select edit option using the context menu then a new popup window appears for editing. If I cancel this popup window and then select another row for edting and submit the popup window after making changes. Chages are being applied on both the rows.(one which i selected earlier and canceled the popup window and then second one for which I made the changes.)
Please guide me If I am doing something wrong. Here is the snippet of my code.$(“#contextmenu”).on(‘itemclick’, function (event) {
var args = event.args;
var rowindex = $(“#customerbookingsgrid”).jqxGrid(‘getselectedrowindex’);
if ($.trim($(args).text()) == “Reschedule Booking”) {
editrow = rowindex;
//alert(editrow);
var offset = $(“#customerbookingsgrid”).offset();
$(“#reschedule_booking_window”).jqxWindow({ position: { x: parseInt(offset.left) + 120, y: parseInt(offset.top) + 1} });// get the clicked row’s data and initialize the input fields.
var dataRecord = $(“#customerbookingsgrid”).jqxGrid(‘getrowdata’, editrow);document.getElementById(‘rtripid’).innerHTML=dataRecord.booking_id;
document.getElementById(‘rcmobileno’).innerHTML=dataRecord.mobile;
document.getElementById(‘rcname’).innerHTML=dataRecord.name;//Format pickup time to 12 hour format.
var picktime = dataRecord.pickup_time;
var timearray = picktime.split(‘:’);
var hrpart = timearray[0];var minpartarray = timearray[1].split(‘ ‘);
var minpart = minpartarray[0];
var timezone = minpartarray[1];var item1 = $(“#rphr”).jqxDropDownList(‘getItemByValue’, hrpart);
$(“#rphr”).jqxDropDownList(‘selectItem’, item1 );var item2 = $(“#rpmin”).jqxDropDownList(‘getItemByValue’, minpart);
$(“#rpmin”).jqxDropDownList(‘selectItem’, item2 );var item3 = $(“#rpampm”).jqxDropDownList(‘getItemByValue’, timezone);
$(“#rpampm”).jqxDropDownList(‘selectItem’, item3 );var tid = dataRecord.booking_id;
var bstatus = dataRecord.status;if(bstatus == ‘Cancelled’ || bstatus == ‘Assigned’){
alert(‘Cancelled/Assigned trips can not be rescheduled.’);
else{
// show the popup window.
$(“#reschedule_booking_window”).jqxWindow(‘show’);$(“#cancelreschedulebtn”).one(‘click’,function() {
$(“#reschedule_booking_window”).jqxWindow(‘close’);});
//Edit existing booking.
$(“#reschedulebookingbtn”).one(‘click’,function() {
$(‘#submit’).jqxButton({disabled: true });
type: “POST”,
url: “update_driver_queue.php?type=RescheduleCustomerBooking” + “&bookingid=” + tid,
data: $(‘#reschedulebookingform’).serialize(),
error: function(request)
alert(‘No Server Access’);
return false;
success: function(data)
{if (data == -1)
alert(“**ERROR**: Could not reschedule booking. !!”);
else if(data >= 1)
alert(‘Trip id ‘ + tid + ‘ has been rescheduled.’ );
refresh_booking_grid();
//window.location=”CustomerBookings.php”;
else
alert(“Error – Please try again later.”);
}//else
});Hi Rajeev,
Please, post a small sample which demonstrates your scenario. Please, prepare the sample in JSFiddle or at least format the code by using the “code” button in the Forum’s toolbar.
http://www.jqwidgets.comTried to format and cutshort it a little, hope it’s better and understandable now.
editrow = rowindex;
$(“#reschedule_booking_window”).jqxWindow({ position: { x: parseInt(offset.left) + 120, y: parseInt(offset.top) + 1} });var dataRecord = $(“#customerbookingsgrid”).jqxGrid(‘getrowdata’, editrow);
document.getElementById(‘rcname’).innerHTML=dataRecord.name;$(“#reschedule_booking_window”).jqxWindow(‘show’);
type: “POST”,
return false;
if (data == -1)
else if(data >= 1)
else
}//else
});Hi Rajeev,
It is not better. We need to run your sample and test it Online. Unfortunately, we cannot test it in the way it is now. Please, post a http://jsfiddle.net/ demo of your scenario.
