jQuery UI Widgets Forums Grid Jqxgrid row Background Problem
This topic contains 1 reply, has 2 voices, and was last updated by  Vladimir 9 years, 8 months ago.
  • Jqxgrid row Background Problem #75816
    jumpstart
    I am using Jqxgrid to show some data.
    I am setting the background color for the rows in specific column.
    Here is my code,basically I am looping through my data and based on some conditions i decide the row color of specific column.
    Now my problem is if i apply filter to my jqxgrid data , row coloring does not work properly
    var cellclass = function (row, columnfield, value)
    var oldValue=””;
    if (row == “0”) {
    oldValue=value;
    colorValue=’red’;
    return colorValue;
    else
    var data = $(‘#new_grid_data2’).jqxGrid(‘getrowdata’, row – 1);
    var valueOfPrevious=data.ips;
    var currValue=value.substr(0,value.lastIndexOf(“.”)+1);
    var previousValu=valueOfPrevious.substr(0,valueOfPrevious.lastIndexOf(“.”)+1);
    if (currValue==previousValu)
    if(colorValue==”red”)
    return ‘red’;
    }else {
    colorValue=””;
    return ”;
    else {
    if(colorValue==””)
    colorValue=”red”;
    }else {
    colorValue=””;
    return colorValue;
    if (value < 20) {
    return ‘red’;
    else if (value >= 20 && value < 50) {
    return ‘yellow’;
    else return ‘green’;
    Jqxgrid row Background Problem #75819
    Vladimir
    Hello jumpstart,
    Your logic relies on comparison relating to the previous row from the original unsorted and unfiltered data (due to the fact it is based on row id).
    So I guess that sorting/filtering would not change that logic in any way and it will keep same formatting for the same row.
    If you would like to get the visible rows information and use them as reference points, you should get them from getrows or getdisplayrows and cycle through them to get the relevant row ID for your evaluation.
    Vladimir
