jQuery UI Widgets › Forums › Grid › jqxgrid problem
Tagged: DropDownList, editor, grid, jqxDropDownList, jqxgrid, Knockout, refresh
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 12 years, 3 months ago.
Authorjqxgrid problem Posts
Hi Jqxgrid team.
I got 2 problems to need your help.
1. when I put dropdownlist in grid by using KO mapping. It doesnt work. It will show [function……..] Please see my simple code below
2. I turn on virtualmode and use function rendergridrows call ajax to get data 10 rows from server by each time. I found that total record is incorrect, then I put command “$(“jqxgrid”).jqxGrid(‘updatebounddata’);” to refresh grid. it always call function rendergridrows.
Is it possible to refresh grid without calling function rendergridrows?Thank you.
<!DOCTYPE html><html lang="en"><head> <title id='Description'>In this sample is illustrated how to create a Grid with column which displays values from foreign data source. The DropDownList editor associated to the column is populated from the foreign data source.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../scripts/knockout-2.2.1.js"></script> <script type="text/javascript" src="../../scripts/knockout-mapping-2.0.0.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(); var personViewModel; var source = {"PersonalRelationship":[ {"Guid":"a5da967e-e89c-49e8-ba53-52fb28aefb1f","ID":0,"Text":"AAAAAA","DisplayText":null}, {"Guid":"4e202e3f-cb29-4949-bb12-a4c7f1f4e88c","ID":0,"Text":"BBBBBB","DisplayText":null}, {"Guid":"e561bcfe-affe-426e-b189-ecbd5183beab","ID":0,"Text":"CCCCCC","DisplayText":null}]}; personViewModel = ko.mapping.fromJS(source); // prepare the data var gridSource = { datatype: "array", localdata: [ { No: 1 }, { No: 2 }, { No: 3 }, { No: 4 } ] }; $("#jqxgrid").jqxGrid( { width: 400, source: gridSource, theme: theme, selectionmode: 'singlecell', autoheight: true, editable: true, columns: [ { text: 'No', datafield: 'No', width: 40, align: 'center', cellsalign: 'center'}, { text: 'Type', datafield: 'type', columntype: 'dropdownlist', createeditor: function (row, value, editor) { editor.jqxDropDownList({ source: personViewModel.PersonalRelationship, displayMember: 'Text', valueMember: 'Guid' }); } }, ] }); }); </script></head><body class='default'> <div id='jqxWidget'> <div id="jqxgrid"> </div> </div></body></html>
Hello Sacrifice,
1) Here is a working example:
<!DOCTYPE html><html lang="en"><head> <title id='Description'>In this sample is illustrated how to create a Grid with column which displays values from foreign data source. The DropDownList editor associated to the column is populated from the foreign data source.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../scripts/knockout-2.2.1.js"></script> <script type="text/javascript" src="../../scripts/knockout-mapping-2.0.0.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(); var getData = function () { var PersonalRelationship = [ { "Guid": "a5da967e-e89c-49e8-ba53-52fb28aefb1f", "ID": 1, "Text": "AAAAAA", "DisplayText": null }, { "Guid": "4e202e3f-cb29-4949-bb12-a4c7f1f4e88c", "ID": 2, "Text": "BBBBBB", "DisplayText": null }, { "Guid": "e561bcfe-affe-426e-b189-ecbd5183beab", "ID": 3, "Text": "CCCCCC", "DisplayText": null } ]; return PersonalRelationship; }; var viewModel = function (items) { this.items = ko.observableArray(items); this.index = ko.observable(0); }; var model = new viewModel(getData()); var source = { localdata: model.items, datatype: 'observablearray' } var dataAdapter = new $.jqx.dataAdapter(source); var gridSource = { datatype: "array", localdata: [ { No: 1 }, { No: 2 }, { No: 3 }, { No: 4 } ] }; $("#jqxgrid").jqxGrid( { width: 400, source: gridSource, theme: theme, selectionmode: 'singlecell', autoheight: true, editable: true, columns: [ { text: 'No', datafield: 'No', width: 40, align: 'center', cellsalign: 'center' }, { text: 'Type', datafield: 'type', columntype: 'dropdownlist', createeditor: function (row, value, editor) { editor.jqxDropDownList({ source: dataAdapter, displayMember: 'Text', valueMember: 'Guid' }); } }, ] }); }); </script></head><body class='default'> <div id='jqxWidget'> <div id="jqxgrid"> </div> </div></body></html>
2) To refresh the grid without calling rendergridrows, please use the refresh method.
