jQuery UI Widgets Forums Grid jqxgrid performance issue & additional features
This topic contains 2 replies, has 2 voices, and was last updated by  raj 10 years, 10 months ago.
  • raj
    We are planning to buy the licensed version
    1) However, while perform the aggregation on grouping with multiple columns(grouping done dynamically – “addgroup” method) under the groupsrenderer event. For an each addgroup method it invokes the groupsrenderer event so here we facing performance issue
    for an two level of pivoting it took 4 to 5 sec. please give me any suggestion to increase the performance.
    2) On grouping, while perform the aggregation on different column, that the values are applied to group header cell(i.e., aggregated column cell).
    3) We need different group header color(forecolor applied to header only, not for inner row content) based on levels of grouping(for eg.: first level–>”Red”, Second level–> green and so on), whether it is possible to do that or not.
    Hi raj,
    Sorry, but we cannot provide a solution for increasing the performance from the provided information.
    raj
    Hi peter stoev,
    We using jQWidgets 3.4.0 latest script, For the third point, our requirement is like that
    Consider the Link : http://s12.postimg.org/a9pir5cil/jqxwidgetgrid.jpg
    please find the following code
        <title id='Description'>Demo</title>
        <link rel="stylesheet" href="../Assets/jqwidgets/styles/jqx.base.css" type="text/css" />
        <script src="../Assets/Scripts/jquery-1.11.1.js" type="text/javascript"></script>
        <script src="../Assets/jqwidgets/jqx-all.js" type="text/javascript"></script>
         <style type="text/css">
            .jqx-grid-group-cell
                border-left-width: 1px;
                border-right-width: 1px;
        </style>
                var depart = [{
                    department: "Dept1",
                    project: "p1",
                    person: "a",
                    planhrs: 10,
                    salary: 5000
                    project: "p1",
                    person: "b",
                    planhrs: 5,
                    salary: 5500
                    department: "Dept2",
                    project: "p2",
                    person: "c",
                    planhrs: 10,
                    salary: 500
                    project: "p1",
                    person: "d",
                    planhrs: 20,
                    salary: 25000
                    project: "p2",
                    person: "e",
                    planhrs: 30,
                    salary: 50
                var source = {
                    datafields: [{
                        type: 'string'
                        type: 'string'
                        type: 'string'
                        type: 'int'
                        type: 'int'
                    localdata: depart
                var theme = 'office';
                var toThemeProperty = function (className) {
                    return className + " " + className + "-" + theme;
                var groupsrenderer = function (text, group, expanded, data) {
                    if (data.groupcolumn.datafield == 'planhrs' || data.groupcolumn.datafield == 'department' || data.groupcolumn.datafield == 'project' || data.groupcolumn.datafield == 'person') {
                        var number = dataAdapter.formatNumber(group, data.groupcolumn.cellsformat);
                        var text = data.groupcolumn.text + ': ' + number;
                        if (data.subItems.length > 0) {
                            var aggregate = this.getcolumnaggregateddata('planhrs', ['sum'], true, data.subItems);
                            var aggregate1 = this.getcolumnaggregateddata('salary', ['sum'], true, data.subItems);
                        } else {
                            var rows = new Array();
                            var getRows = function (group, rows) {
                                if (group.subGroups.length > 0) {
                                    for (var i = 0; i < group.subGroups.length; i++) {
                                        getRows(group.subGroups[i], rows);
                                } else {
                                    for (var i = 0; i < group.subItems.length; i++) {
                                        rows.push(group.subItems[i]);
                            getRows(data, rows);
                            var aggregate = this.getcolumnaggregateddata('planhrs', ['sum'], true, rows);
                            var aggregate1 = this.getcolumnaggregateddata('planhrs', ['sum'], true, rows);
                        var tt = "<div style=\"width: 100%; float: left;\"><div style=\"width: 20%; float: left;\">" + number + "</div><div style=\"width: 20%; float: left;\">&nbsp;</div><div style=\"width: 20%; float: left;\">&nbsp;</div><div style=\"width: 20%; float: left;text-align:right;\">" + aggregate.sum + "</div><div style=\"width: 20%; float: left;text-align:right;\">" + aggregate1.sum + "</div></div>";
                        return tt;
                        console.log(tt);
                    } else {
                        return '<div class="' + toThemeProperty('jqx-grid-groups-row') + '" style="position: absolute;"><span>' + text + '</span>';
                $("#jqxgrid").jqxGrid({
                    width: '100%',
                    autorowheight: true,
                    altrows: true,
                    groupable: true,
                    groupsrenderer: groupsrenderer,
                    groupsexpandedbydefault: true,
                    selectionmode: 'singlecell',
                    altrows: true,
                    columns: [{
                        text: 'department',
                        datafield: 'department', widht: 'auto'
                        text: 'project',
                        datafield: 'project', widht: 'auto'
                        text: 'person',
                        datafield: 'person', widht: 'auto'
                        text: 'planhrs',
                        datafield: 'planhrs',
                        cellsalign: 'right', widht: 'auto'
                        text: 'salary',
                        datafield: 'salary',
    <body>
        <div id='jqxWidget'>
            <div id="jqxgrid">
