jQuery UI Widgets Forums Angular JQXGRID Height using Percentage
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 7 years, 6 months ago.
  • JQXGRID Height using Percentage #97584
    Gary
    I have the following allocations for jqxGrid for Height:
    <jqxGrid #gridColumns
    [width]=”‘99%'” [height]=”‘100%'” [source]=”dataAdapter” [columns]=”columns”
    [theme]=”‘energyblue'” [pageable]=”false” [autoheight]=”false” [sortable]=”true” [altrows]=”false”
    [enabletooltips]=”true” [selectionmode]=”‘singlerow'” [editable]=”false” [rowsheight]=”25″
    [showstatusbar]=”true” [renderstatusbar]=”createButtonsContainers” [statusbarheight]=”37″
    (onRowclick)=”onRowClick($event)”>
    </jqxGrid>
    When set with the percentage my grid always shows as 400px height, which is the default.
    I get no error.
    When I define height with a px size as below it works fine. I can adjust to any px size.
    [width]=”‘99%'” [height]=”‘593.8′” [source]=”dataAdapter” [columns]=”columns”
    </jqxGrid>
    The problem I need a fluid definition for resizing.
    Currently using JQWIDGETS 5.4.0 with Angular 5.0.3
    Gary
    JQXGRID Height using Percentage #97588
    Hi Gary,
    We have such example already: https://www.jqwidgets.com/angular/angular-grid/angular-grid-fluidsize.htm.
    Hope this helps.
    JQXGRID Height using Percentage #97609
    Gary
    Peter,
    I found my error. I had embedded jQXGrid inside JQXTab. The Height in JQXTAB was set wrong and JQXGrid was getting 100% of what JQXTAB had allocated.
    My error.
    Gary
    JQXGRID Height using Percentage #97612
    Thanks for the update, Gary.
    Have a nice day.
