jQuery UI Widgets Forums Grid JqxGrid header Right click event
This topic contains 2 replies, has 2 voices, and was last updated by  Dimitar 11 years, 6 months ago.
  • JqxGrid header Right click event #39968
    anshu
    Hi ,
    I am using a JqxGrid and dynamically picking its column header and craeted a ‘contextmenu’ event for this which will open a context menu on right click .
    This seems to work fine once i launch the UI and try it first time but once context menu opens and is used , this right click event doesnot fire.
    $(“#jqxgrid”).find(“#columntablejqxgrid”).on(‘contextmenu’, function (event) {
    $(“#jqxgrid”).find(“#columntablejqxgrid”).css({“color”:”red”,”border”:”2px solid red”})
    contextMenu.jqxMenu(‘open’, parseInt(event.clientX) + 5 + scrollLeft, parseInt(event.clientY)
    + 5 + scrollTop);
    return false;
    Please suggest on this .
    JqxGrid header Right click event #40520
    anshu
    Here I am atatching the code which i used to craete a context menu for grid using the ‘columntablejqxgrid`
    <html>
    <title id=’Description’>Right-Click on a jqxGrid Row to open a Context Menu.</title>
    <link rel=”stylesheet” href=”jqwidgets/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”scripts/jquery-1.10.2.min.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxmenu.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxgrid.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxgrid.pager.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxgrid.selection.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxnumberinput.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxwindow.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxdropdownlist.js”></script>
    <script type=”text/javascript” src=”scripts/gettheme.js”></script>
    <script type=”text/javascript” src=”jqwidgets/jqxcheckbox.js”></script>
    <script type=”text/javascript” src=”scripts/generatedata.js”></script>
    var theme = “”;
    var data = generatedata(25);
    //prepare the source
    localdata: data,
    datatype: “array”,
    datafields:
    { name: ‘price’, type: ‘number’ }
    //data adapter for grid
    var editrow = -1;
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid(
    width: 670,
    { text: ‘First Name’, datafield: ‘firstname’, width: 100 },
    { text: ‘Last Name’, datafield: ‘lastname’, width: 100 },
    { text: ‘Product’, datafield: ‘productname’, width: 190 },
    { text: ‘Quantity’, datafield: ‘quantity’, width: 90, cellsalign: ‘right’ },
    { text: ‘Price’, datafield: ‘price’, cellsalign: ‘right’, cellsformat: ‘c2’ }
    //list source for column chooser popup
    var listSource = [
    { label: ‘First Name’, value: ‘firstname’, checked: true },
    { label: ‘Last Name’, value: ‘lastname’, checked: true },
    { label: ‘Product’, value: ‘productname’, checked: true },
    { label: ‘Quantity’, value: ‘quantity’, checked: true },
    { label: ‘Price’, value: ‘price’, checked: true}
    //initialize the column chooser list
    $(“#columnList”).jqxListBox({ source: listSource, width: 200, height: 200, theme: theme, checkboxes: true });
    // code for check box selection
    $(“#columnList”).on(‘checkChange’, function (event)
    //grid coulumn show hide on check box click
    $(“#jqxgrid”).jqxGrid(‘beginupdate’);
    if (event.args.checked)
    $(“#jqxgrid”).jqxGrid(‘showcolumn’, event.args.value);
    else
    $(“#jqxgrid”).jqxGrid(‘hidecolumn’, event.args.value);
    $(“#jqxgrid”).jqxGrid(‘endupdate’);
    // create context menu
    var contextMenu = $(“#Menu”).jqxMenu({ width: 200, height: 58, autoOpenPopup: false, mode: ‘popup’, theme: theme });
    // assign context menu to grid
    $(“#jqxgrid”).on(‘contextmenu’, function () {
    return false;
    // handle context menu clicks.
    $(“#Menu”).on(‘itemclick’, function (event) {
    var args = event.args;
    if ($.trim($(args).text()) == “Choose Column”)
    $(“#popupWindow”).jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    // show the popup window.
    $(“#popupWindow”).jqxWindow(‘show’);
    //gird column header click event
    //var column = event.args.datafield;
    //if (event.which === 3) {
    //column = event.args.datafield;
    contextMenu.jqxMenu(‘open’, parseInt(event.clientX) + 5 + scrollLeft, parseInt(event.clientY) + 5 + scrollTop);
    return false;
    // initialize the popup window .
    $(“#popupWindow”).jqxWindow({ width: 250, resizable: false, theme: theme, isModal: true, autoOpen: false, modalOpacity: 0.01,title :”Choose Column” });
    <body class=’default’>
    <div id=’jqxWidget’>
    <div id=”jqxgrid” ></div>
    <div style=”margin-top: 30px;”>
    <div id=”cellbegineditevent”></div>
    <div style=”margin-top: 10px;” id=”cellendeditevent”></div>
    <div id=”popupWindow”>
    <div id=”columnList”></div>
    <div id=’Menu’>
    • Choose Column
    JqxGrid header Right click event #43664
    Hello anshu,
    We tested your example, but did not experience the same issue. The context menu could be shown multiple times on right click. Please make sure you are using the latest version of jQWidgets (3.0.4).
    You may also find the example in the forum topic Custom Context Menu for Column helpful.
