jQuery UI Widgets Forums Angular jqxgrid group renderer add more info
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 5 years, 3 months ago.
  • jqxgrid group renderer add more info #111549
    Romain
    I read this Example and I would like to do something like that. In the example we put aggregate info into groupsrenderer.
    I got products with informations : code, description, country, notes and quantity. I would like when i group by product, the name of this product appear in the renderer.
    I got it when there is 1 level of groups but when i got 2 groups (code and country) I don’t get the name.
    jqxgrid group renderer add more info #111576
    Hello Romain,
    Could you clarify it?
    The mentioned from you example, it provides enough information to achieve this.
    With each iteration, it goes to inner (next level) groups with details about it.
    Please, provide us with more details on what exactly you want to achieve and also, an example for better understanding.
    https://www.jqwidgets.com
