jQuery UI Widgets Forums Getting Started JQXgrid column header issue
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 8 months ago.
  • JQXgrid column header issue #31755
    sac
    We are using Jquery date picker control along with JQXGrid.
    When date picker pops-up theJQXgrid header is get displayed on top and (see screen shot) we are facing same issue with top menu option.
    >>  We have tried to fix this using below CSS
    .jqx-grid-column-header{z-index:0!important;}
    But after fixing this we observed that JQXgrid headers are not remain frozen in case of frozen columns.
    JQXgrid column header issue #31758
    Hi sac,
    jqxDateTimeInput’s Popup has much higher z-index compared to the Grid’s Header. I also do not suggest you to change Layout/Z-Index settings in the CSS.
    JQXgrid column header issue #32397
    sac
    This issue is not only exist with Datepicker. We are having top menu which also goes hidden due to JQXGrid header.
    JQXgrid column header issue #32399
    Hi sac,
    The solution that I can suggest you is to update the z-index of the date picker’s popup that you use on your page or use jqxDateTimeInput instead.
