jQuery UI Widgets Forums Grid JqxGrid Checkbox selection mode problem when filtering
This topic contains 4 replies, has 2 voices, and was last updated by  smr 11 years, 2 months ago.
  • smr
    Hi. I am using jqxgrid 3.2.2 version.
    I have a problem with checkbox selection mode my problem is that ;
    When normally i check a checkbox it selects the row and works fine,but when i filter a colum and then try to select a row with checkbox it does’n work. Here is my code :
     $("#jqxgrid2").jqxGrid({
    		    autoheight: false,
    		    autoshowfiltericon: true,
    		    columnsreorder: true,
    		    enabletooltips: true,
    		    groupable: true,
    		    pagesizeoptions: ['10', '20', '30', '50', '100', '250', '500', '1000'],
    		    pagesize: 20,
    		    showfiltermenuitems: true,
    		    selectionmode: 'checkbox',
    		    showfilterrow: true,
    		    virtualmode: true,
    		    width: 750,
    		    height: 450,
    		    Theme: 'bootstrap',
    		    source: dataadapter,
    		        return obj.data;
    		    columns: R_KOLONLAR,
                        ready: function () {
    Hi smr,
    The solution is:
    1. Remove
    return obj.data;
    2. Remove virtualmode
    smr
    hi i modified my code as you wish,but it doesnt solve the problem.
    I solve the problem by changing the selection mode to the multiplerows this works fine when filtering too.
    Thanks for your interest
    Hi smr,
    Don’t know how to reproduce your problem, but with jQWidgets 3.2.2, the Checkbox Selection works even if a filter is applied. Example: http://jsfiddle.net/XHa7w/
    smr
    Hi my problem was because of filter callback function at my dataadapter object
     filter: function () {
    removing this callback function solved my problem.
    Again thanks for your interest Peter
