jQuery UI Widgets Forums Angular JQXGrid autorowheight issue
This topic contains 4 replies, has 2 voices, and was last updated by  vijay.vanecha 5 years, 11 months ago.
  • JQXGrid autorowheight issue #106167
    vijay.vanecha
    I am using autorowheight option in jqxgrid, cell value is multiline so i set css for that column ‘white-space: pre’ throught cellclassname. I am using HTML as below:
    <jqxGrid #listGrid [width]="'100%'" [enabletooltips]="true" [autoheight]="true" [autorowheight]="true" [source]="listDataAdapter" [columns]="columns" [pageable]="true" [sortable]="true" [filterable]="true" [autoloadstate]="true" [columnsmenu]="false" [columnsresize]="true" [columnsreorder]="true"> </jqxGrid>
    Issue is, While resizing browser, row height is increasing. when i use mouse scroll on grid, row height is increasing as much i scroll.
    Help me to find what is wrong.
    JQXGrid autorowheight issue #106179
    Hello vijay.vanecha,
    Could you provide us with one simplified example that demonstrates your case?
    As a base, you could use this example.
    https://www.jqwidgets.com
    JQXGrid autorowheight issue #106190
    vijay.vanecha
    Hi Hristo,
    Thanks for quick reply.
    Here is simplified example. Try to scroll in grid.
    I found that when i use createwidget in column this issue occurs.
    Please check and let me know what is wrong in my example.
    Vijay
    JQXGrid autorowheight issue #106207
    I would like to suggest you look at this topic where we has a similar discussion.
    Also, please, take a look at this example.
    JQXGrid autorowheight issue #106214
    vijay.vanecha
    Hi Hristo,
    You are Awesome!
    Thanks a lot for solution.
    This two lines works for me.
    htmlElement.style.overflow = "hidden";
    htmlElement.style.maxHeight = "30px";
    Thanks again,
    Vijay
