jQuery UI Widgets Forums Grid jqxgrid autoheight sets incorrect height when paging disabled
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 4 months ago.
  • jignyasa
    Basically i am facing 3 related issues. All related to pagination
    1) setting autoheight: true does not calculate the correct grid height when pageable property is false. So some rows are hidden when rendered.
    2) The pagesize dropdown does not show correctly i.e the dropdown list is not shown when clicked on the dropdown. So i would want to disable it altogether. But as mentioned above it gives issue mentioned above.
    Jignyasa
    Hi Jignyasa,
    1. “autoheight” = true means that the Grid’s height would be calculated as a Sum of the Height of all Rows. If you think that it does not work correctly, then provide a sample which demonstrates it.
    2. Ok, send us a sample about that, too so we can check whether there’s a problem on our side or there’s something which should be modified on your side.
    jignyasa
    Please find the sample code.
    Similar code however works in other places.
    type: ‘POST’,
    { name: ‘col1’, type: ‘String’ },
    { name: ‘col2’, type: ‘number’ },
    root: “”,
    record: “”,
    url: url
    loadComplete: function (data) {console.log(data);
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid(
    width: 1230,
    theme: ‘energyblue’,
    showstatusbar: true,
    statusbarheight: 25,
    pageable:true,
    altrows: true,
    enabletooltips: true,
    editable: false,
    showaggregates:true,
    { text: ‘Name’, datafield: ‘col1’, width: 150 },
    { text: ‘Total’, datafield: ‘col2’, width: 100, aggregates:[‘sum’],
    aggregatesrenderer: function (aggregates, column, element) {
    var renderstring = ‘‘+aggregates[‘sum’]+’‘;
    console.log(aggregates[‘sum’]);
    return renderstring;
    text : ‘Draw’,
    columntype : ‘button’,
    width: 100,
    cellsrenderer : function() {
    return “Draw”;
    buttonclick : function(row) {
    editrow = row;
    url:contextPath+”/getMarks.json”,
    type:”POST”,
    data:”name=”+dataRecord.col1,
    success:function(data){
    console.log(data);
    var figImg = document.getElementById(“figure”);
    var imgPath = ““;
    figImg.innerHTML = imgPath;
    $(‘#chartWindow’).jqxWindow(‘open’);
    error : function (XMLHttpRequest, textStatus, errorThrown) {
    alert(errorThrown);
    Jignyasa
    Hi Jignyasa,
    Unfortunately, I am unable to reproduce the reported behavior using the provided code. My test sample based on your code is below:
        <title id='Description'>This example shows how to create a Grid from Array data.</title>
        <script type="text/javascript" src="../../jqwidgets/jqxgrid.aggregates.js"></script>
                var url = "";
                     type: 'POST',
                     { name: 'col1', type: 'String' },
                     { name: 'col2', type: 'number' },
                     root: "",
                     record: "",
                     url: url
                        console.log(data);
                $("#jqxgrid").jqxGrid(
                    width: 1230,
                    theme: 'energyblue',
                    altrows: true,
                    editable: false,
                    showaggregates: true,
                    { text: 'Name', datafield: 'col1', width: 150 },
                        text: 'Total', datafield: 'col2', width: 100, aggregates: ['sum'],
                            if (aggregates && aggregates['sum']) {
                                var renderstring = '' + aggregates['sum'] + '';
                                console.log(aggregates['sum']);
                            else return "";
                        text: 'Draw',
                        columntype: 'button',
                        width: 100,
                        cellsrenderer: function () {
                            return "Draw";
                        buttonclick: function (row) {
                            editrow = row;
                            var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', editrow);
                                url: contextPath + "/getMarks.json",
                                type: "POST",
                                data: "name=" + dataRecord.col1,
                                success: function (data) {
                                    console.log(data);
                                    var figImg = document.getElementById("figure");
                                    var imgPath = "";
                                    $('#chartWindow').jqxWindow('open');
                                error: function (XMLHttpRequest, textStatus, errorThrown) {
                                    alert(errorThrown);
        <div id='jqxWidget'>
            <div id="jqxgrid">
