jQuery UI Widgets › Forums › Angular › jqxGrid angular – widget column issue
Tagged: angular grid, grid, typescript grid, widget column
This topic contains 8 replies, has 2 voices, and was last updated by vijay.vanecha 5 years, 9 months ago.
When i use widget column in jqxGrid, after vertical scroll in grid widget column cell value mismatches with actual row data.
You can see this issue in jqxGrid demo also. jqxGrid > Columns > Widget Column > Demo
Scroll vertically slowly and observe picture on left and name is mismatching after scroll.
Please help.
VijayHello Vijay,
Thank you for the feedback.
It is a known cause.
There is missing implementation for theinitwidget
callback.
However, you could find the working demo with mentioned implementation.Best Regards,
Hristo HristovjQWidgets team
https://www.jqwidgets.comHi Hristo,
Thanks for quick reply.
I have to set multiple action buttons in widget column. But it will show/hide condition based.
I followed your demo but not works. I created example from demo you given.
Please guide me where i am wrong.
VijayHello Vijay,
Thanks for example. it works perfectly.
As per my requirement i implemented the same. but not working in my case.
In my case, User can delete only newly added rows. So i have set one column for rowstatus. Set rowstatus = 0 for already exist rows. While adding new row i set rowstatus = 1.
While i am adding new row. Delete button does not appears to new row.
Please, take a look at this example created for my case.
VijayHello Vijay,
You should add some additional settings – to bind toclick
event of the new button in theinitwidget
callback.
Because, it is invoked in that moment.Also, I would like to suggest you an another option that you could use to create column with buttons and depends on the case to show it or not.
I would like to suggest you look at this demo.
With adding of an additional class (cellclassname
property) depends on the case to hide some of the buttonsBest Regards,
https://www.jqwidgets.comHi Histro,
As you said, i have to add some additional settings to bind
click
event or new button ininitwidget
callback.Please give some hint of how could i do this. I need to set
addEventHandler
again for that button ininitwidget
?Thanks again,
VijayHello Vijay,
I suggest you just hide the buttons where you do not have to see it and add wonted functionality when clicking on the button there.
Please, take a look at this example.Also, I would like to suggest you look at another approach which will be more easy to use for your case:
https://stackblitz.com/github/jqwidgets/angular/tree/master/grid/popupediting/Best Regards,
Thanks for reply.
We have implemented second option as you suggested. Working as expected.
Thanks again for your support,
Vijay -
