jQuery UI Widgets › Forums › General Discussions › Lists › DropDownList › jqxDropDownList on jqxWindow issue
Tagged: DropDownList, jqxDropDownList, jqxwindow, pop-up, popup, popup not showing options, popupZIndex, window, z-index
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 10 years, 4 months ago.
DropDownList options on a jqxWindow show behind the window. Kind of zindex problem.
To verify, I modified just a little your jqxwindow/jquery-window-api.htm example ( http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxwindow/index.htm?(arctic)#demos/jqxwindow/jquery-window-api.htm )
adding a jqxDropDownList :
<html lang=”en”>
<meta name=”keywords” content=”jQuery Window, Window Widget, Window” />
<meta name=”description” content=”Show, Hide, Pin, Unpin or Open and Close the jqxWindow through its API functions.” />
<title id=’Description’>Show, Hide, Pin, Unpin or Open and Close the jqxWindow through its API functions.</title>
<script type=”text/javascript” src=”../../jqwidgets/jqxwindow.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxpanel.js”></script>
var customButtonsDemo = (function () {
var _collapsed = false;function _addEventListeners() {
$(‘#showWindowButton’).mousedown(function () {
$(‘#customWindow’).jqxWindow(‘open’);
$(‘#hideWindowButton’).mousedown(function () {
$(‘#customWindow’).jqxWindow(‘close’);
$(‘#pinWindowButton’).mousedown(function () {
$(‘#customWindow’).jqxWindow(‘draggable’, false);
$(‘#unpinWindowButton’).mousedown(function () {
$(‘#customWindow’).jqxWindow(‘draggable’, true);
_addCustomButtonsHandlers();
_addSearchInputEventHandlers();
};function _addCustomButtonsHandlers() {
$(‘#pinButton’).mousedown(function () {
if ($(‘#customWindow’).jqxWindow(‘draggable’)) {
} else {
$(‘#collapseWindowButton’).mousedown(function () {
$(‘#customWindow’).jqxWindow(‘collapse’);
$(‘#expandWindowButton’).mousedown(function () {
$(‘#customWindow’).jqxWindow(‘expand’);
};function _addSearchInputEventHandlers() {
$(‘#searchTextInput’).keydown(function () {
_searchButtonHandle();
$(‘#searchTextInput’).change(function () {
$(‘#searchTextInput’).keyup(function () {
$(document).mousemove(function () {
};function _searchButtonHandle() {
if ($(‘#searchTextButton’).length > 0) {
if ($(‘#searchTextInput’).val() !== ”) {
$(‘#searchTextButton’).jqxButton(‘disabled’, false);
} else {
$(‘#searchTextButton’).jqxButton(‘disabled’, true);
$(‘#cancelButton’).jqxButton(‘disabled’, false);
};function _createElements() {
var source = [
“Affogato”,”Americano”,”Bicerin”,”Breve”,”Café Bombón”,”Café au lait”,”Caffé Corretto”,”Café Crema”,
“Caffé Latte”,”Caffé macchiato”,”Café mélange”,”Coffee milk”,”Cafe mocha”,”Cappuccino”,”Carajillo”,
“Cortado”,”Cuban espresso”,”Espresso”,”Eiskaffee”,”The Flat White”,”Frappuccino”,”Galao”,”Greek frappé coffee”,
“Iced Coffee”,”Indian filter coffee”,”Instant coffee”,”Irish coffee”,”Liqueur coffee”
];$(‘#showWindowButton’).jqxButton({ width: ’80px’});
$(‘#hideWindowButton’).jqxButton({ width: ’80px’ });
$(‘#pinWindowButton’).jqxButton({ width: ’80px’ });
$(‘#unpinWindowButton’).jqxButton({ width: ’80px’ });
$(‘#collapseWindowButton’).jqxButton({ width: ’80px’ });
$(‘#expandWindowButton’).jqxButton({ width: ’80px’ });
$(“#jqxContrato”).jqxDropDownList({
theme: ‘energyblue’, selectedIndex: 0, source: source, displayMember: “descrip”, valueMember: “idcontrato”, width: 150, height: 25
});$(‘#customWindow’).jqxWindow({ width: 400,
height: 180, resizable: false,
cancelButton: $(‘#cancelButton’),
initContent: function () {
$(‘#searchTextButton’).jqxButton({ width: ’80px’, disabled: true });
$(‘#cancelButton’).jqxButton({ width: ’80px’, disabled: false });
$(‘#matchCaseCheckBox’).jqxCheckBox({ width: ‘150px’ });
};return {
init: function () {
_createElements();
_addEventListeners();
} ());$(document).ready(function () {
customButtonsDemo.init();
<body class=’default’>
<div style=”width: 100%; height: 650px;” id=”jqxWidget”>
<input type=”button” value=”Open” id=”showWindowButton” />
<input type=”button” value=”Close” id=”hideWindowButton” style=”margin-left: 3px” />
<input type=”button” value=”Pin” id=”pinWindowButton” style=”margin-left: 3px” />
<input type=”button” value=”Unpin” id=”unpinWindowButton” style=”margin-left: 3px” />
<input type=”button” value=”Collapse” id=”collapseWindowButton” style=”margin-left: 3px” />
<input type=”button” value=”Expand” id=”expandWindowButton” style=”margin-left: 3px” />
<div
id=”mainDemoContainer”>
<div id=”customWindow”>
<div id=”customWindowHeader”>
<span id=”captureContainer” style=”float: left”>Find </span>
<div id=”customWindowContent” style=”overflow: hidden”>
<div style=”margin: 10px”>
Fi<u>n</u>d what:
<input type=”text” style=”width: 175px; border: 1px solid #aaa” id=”searchTextInput” /><br/><br/>
<div id=’jqxContrato’ ></div>
<div style=”float: right”>
<input type=”button” value=”Find Next” style=”margin-bottom: 5px;” id=”searchTextButton” /><br />
<input type=”button” value=”Cancel” id=”cancelButton” />
<br />
<br />
<div id=”matchCaseCheckBox”>
Match case</div>
</html>you will see that the options stay behind the window panel
Help please !
Hello omargarro,
jqxDropDownList has a property popupZIndex. Please set it to an appropriate large number (e.g. 99999) and the issue should be gone.
