jQuery UI Widgets › Forums › Grid › jqxDropDownList in jqxGrid,the checkedItem will be null after click few times
This topic contains 2 replies, has 2 voices, and was last updated by bruthe 11 years, 5 months ago.
December 13, 2013 at 7:12 am jqxDropDownList in jqxGrid,the checkedItem will be null after click few times #46455
$(document).ready(function () { var theme = 'office' var source = { datatype: "json", datafields:[ { name: 'username', type: 'string' }, { name: 'email', type: 'string' }, { name: 'teamName', type: 'string' }, { name: 'supervisor', type: 'bool' }, { name: 'id', type: 'int' }, ], url: _BASE_URL + 'team/memberListAsJSON', updaterow: function (rowid, rowdata) { var data = $.param(rowdata); //alert(data) $.ajax({ dataType: 'json', url: _BASE_URL + 'team/updateMember', data: data, success: function (data, status, xhr) { // update command is executed. if(data.success){ //alert("update success!"); var addOpt = $("select#orgMaster option[value='"+data.name+"']") if(data.isSupervisor){ if(!addOpt){ $("select#orgMaster").append("<option value='"+data.name+"'>"+data.name+"</option>") } }else{ addOpt.remove() } }else{ //alert(data.error); } } }); } }; var dataAdapter = new $.jqx.dataAdapter(source,{ downloadComplete: function (data, status, xhr) { }, loadComplete: function (data) { $("#jqxgrid").jqxGrid('hidecolumn', 'id'); }, loadError: function (xhr, status, error) { alert(JSON.stringify(xhr)); } }); var getEditorDataAdapter = function (datafield) { var source = { datatype: "json", datafields: [{name: 'teamName'}], url: _BASE_URL + 'team/orgsName', async: false }; var dataAdapter = new $.jqx.dataAdapter(source, { uniqueDataFields: [datafield] }); return dataAdapter; } // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 858, height:305, source: dataAdapter, pageable: true, editable: true, sortable: true, //theme: theme, theme: theme, filterable: true, //selectionmode: 'multiplecellsadvanced', selectionmode: 'singlecell', columns: [ { text: 'User Name', columntype: 'textbox', datafield: 'username', width: 236 }, { text: 'Email', columntype: 'textbox', datafield: 'email', width: 236 }, { text: 'Organization', columntype: 'template', datafield: 'teamName', width: 150 , createeditor: function (row, cellvalue, editor, celltext, width, height) { // construct the editor. editor.jqxDropDownList({ checkboxes: true, source: getEditorDataAdapter('teamName'), displayMember: 'teamName', valueMember: 'teamName', width: width, height: height, theme: theme, autoDropDownHeight: true, selectionRenderer: function () { return "Please Choose Team:"; } }); }, initeditor: function (row, cellvalue, editor, celltext, pressedkey) { // set the editor's current value. The callback is called each time the editor is displayed. var items = editor.jqxDropDownList('getItems'); editor.jqxDropDownList('uncheckAll'); //var values = cellvalue.split(/,\s*/); var values = cellvalue; for (var j = 0; j < values.length; j++) { for (var i = 0; i < items.length; i++) { if (items[i].label === values[j]) { editor.jqxDropDownList('checkIndex', i); } } } }, geteditorvalue: function (row, cellvalue, editor) { // return the editor's value. return editor.val(); } }, { text: 'Supervisor', columntype: 'checkbox', datafield: 'supervisor'} ] }); // events $("#jqxgrid").on('cellbeginedit', function (event) { var args = event.args; $("#cellbegineditevent").text("Event Type: cellbeginedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value); }); $("#jqxgrid").on('cellendedit', function (event) { var args = event.args; $("#cellendeditevent").text("Event Type: cellendedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value); }); });
the reveal of data have any problem,but have these problem:
1.the jqxDropDownList cell will send ajax request when you double click the element,but the real is
you want to send update request when the checked item is changed
2.Frequent Click the jqxDropDownList cell, the checked item of jqxDropDownList will be null, I can’t
find where the problem–>
jqxDropDownList JSON data:
[{“id”:1,”teamName”:”BullChina”,”parent”:null,”master”:null,”viceMaster”:null,”productOwner”:null}, …]–>
[{“username”:”lei.liu-bj”,”email”:”lei.liu-bj@qq.com”,”teamName”:[“FLEX”],”supervisor”:false},….]anyone can help me ,thank very much !!!
December 16, 2013 at 8:36 am jqxDropDownList in jqxGrid,the checkedItem will be null after click few times #46571Hello bruthe,
- The source callback function updaterow is invoked when the method with the same name has been called;
- Please clarify your issue and post exactly how it can be reproduced. Do you experience it with the demo Custom Column Editor?
http://www.jqwidgets.com/December 18, 2013 at 4:26 am jqxDropDownList in jqxGrid,the checkedItem will be null after click few times #46669Hi Dimitar.
Thank you for you taking time out of your busy schedule to look my problem!I have read the demo ,the problem is jqxDropDownList in grid
can’t update data in real time with background ,and sometime get the checkedItem from background in jqxDropDownList may
not correct. i have already change a another way to edit table.Thank you!
