jQuery UI Widgets › Forums › Grid › jqxDropDownList as cell editor problem
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 11 years, 8 months ago.
I have this grid that has one column which become a dropdown when editing. That works perfectly if the dropdown opens below the cell. But if the dropdown opens above the cell, if you move the mouse from the cell to the list, the list disapear/collapse, thus making it impossible to change the value with the mouse.
How can I make this work?
here is a sample of my grid declaration:
$("#storesGrid").jqxGrid({ theme:"s360", source:storeGridDataAdapter, altrows: true, columns: [ /* many more columns */ { text: '@Messages("stores.column.musicStation")', datafield: 'stationId', width:200, displayfield: 'station', columntype: 'combobox', cellsrenderer: editComboboxCellsRenderer, cellclassname: cellclass, createeditor: function (row, column, editor) { editor.jqxComboBox({source: availableStationsDataAdapter, displayMember: "name", valueMember: "id", autoOpen: true, theme:"s360"}); }, cellvaluechanging: function (row, column, columntype, oldvalue, newvalue) { if(oldvalue == newvalue) { return oldvalue } var validValues = availableStationsDataAdapter.originaldata; for (var i = 0; i < validValues.length; i++) { var curValidValue = validValues[i]; if(curValidValue.id == newvalue.value) { if(curValidValue.name == newvalue.label) { return newvalue; }else { return oldvalue } } } return oldvalue; } } ], width: "100%", height: "100%", groupable: true, editable: true, editmode:"click", sortable: true, showsortcolumnbackground: true, showfilterrow: true, filterable: true, selectionmode: 'none', rowdetails: true, columnsresize: true /* row detail code removed */ /* status bar code removed */ })
Hi reblutus,
Remove “autoOpen: true” and you will have no problem.
http://www.jqwidgets.comIndeed it works! The drawback is that you have to click twice on the cell to edit it. It would be preferable to only click once.
Hi reblutus,
You have to click twice to open the popup, not to open the editor. If you would like, you can use the “open” method to open the ComboBox editor in the “initeditor” callback function of the column.
